Author Topic: wanted  (Read 1840 times)
bigford
wanted
« on: November 25, 2008, 20:01:37 »
 guy's i need 1-1/4 X 1-1/4 (or for you guy on the funny system 30mm) brass square tube about 20'' long and a second piece same lenth that will fit inside
to telescope in and out. i found a shop here in new york that has it BUT i need
to order 16 feet at a time.. i dont need 32 feet of brass
   HELP
more boats then money
pops
    • clayt.com
Re: wanted
« Reply #1 on: November 26, 2008, 03:10:14 »
Hi bigford,
If you run into a dead end maybe you can make them out of K&S brass angles for the corners and brass plate for the four sides. Sounds like your making ducting or  something. I have to build some in a smaller scale to duct air in and out of the engine room of the towboat I'm building. I have some nice 25mm square fans to circulate air but need the duct work for them.
There are several materials vendors at the Cabin Fever show in January that have brass shapes. I can keep an eye out for you if you have not found anything by then.
bigford
Re: wanted
« Reply #2 on: November 26, 2008, 05:04:52 »
pops
  here is what i'm building 1/14 tamiya heavy wrecker
 parts needed are for the inner and outer boom tube
pops
    • clayt.com
Re: wanted
« Reply #3 on: November 26, 2008, 09:41:40 »
Very cool Peterbuilt "boat" there bigford.  ;)
If you could live with ABS plastic, Plastruct has 1.25 square tubing item no. ST-40 that is 14" long or ST-40L that is 30" long. Their other smaller square tubes telescope inside. The only hindrance might be the thicker wall thickness.
