Author Topic: UPDATE re forum image posting bug "error 1784/1994"  (Read 8625 times)
HS93
Re: UPDATE re forum image posting bug "error 1784/1994"
« Reply #15 on: January 13, 2009, 19:36:36 »
I found the best way to get images posted is to
type in your text, submit the post, then
modify the post and add the images the second
time around.
Yes I have been doing that (when I post) becase at times it regecting my pictures and so you lost all the text, I do it the same way on other sites as well if it lets you.
Peter
« Reply #16 on: January 14, 2009, 00:27:25 »
That system used to work for me but lately I cannot post any picture on this site...
TERRY
« Reply #17 on: January 14, 2009, 02:27:30 »
Same here. Have given up trying.
Terry.
Measure twice cut once
HS93
« Reply #18 on: January 14, 2009, 06:48:04 »
the site started to reject previousley used picture names when the picture side bar on the left started, and so I may be wrong but you have to use a name for the picture that is unique.I started getting a bit fed up after doing a wright up and it getting lost for the second time hence the post then modify and put pictures on , I think if you use your own unnique names there is not a problem but by time I had discoverd this I had been a bit put off, I also right click on mouse then copy befor posting then if it goes wrong you have not lost all your typing (I do this on all sites I post on)
Peter
HS93
« Reply #19 on: January 14, 2009, 06:49:07 »
first attemt to post this went to page not found   :-X   >:(
Peter
« Reply #20 on: January 14, 2009, 06:52:41 »
Hmmm...let me try something.....
« Reply #21 on: January 14, 2009, 06:55:42 »
...and again
By George, Peter...you could be on to something here!!
« Reply #22 on: January 14, 2009, 07:17:46 »
All my pictures have unique names, so it does not help me. that said, I have just succeeded in posting a picture, but it did take many attempts. I'll try another here..
HS93
« Reply #23 on: January 14, 2009, 07:35:47 »
I have just tried to post a picture with a previousley used name "Leslie Ann at Van Isle.jpg" and it went to a conection problem after a few min , I will try again
Peter
HS93
« Reply #24 on: January 14, 2009, 07:40:10 »
Nope got this now
Database Error: Lost connection to MySQL server during query
File: /home/content/m/o/d/modeltugforum/html/Sources/Subs-Post.php
Line: 1784
HS93
« Reply #25 on: January 14, 2009, 07:44:36 »
I give up wont let me post any pictures
Peter
HS93
« Reply #26 on: January 14, 2009, 13:55:18 »
test with BMP   wow it let me post a bmp but not a jpg
Peter
HS93
« Reply #27 on: January 14, 2009, 13:59:14 »
test with a JPG
TugMaster
  • Administrator
  • Welcome Aboard !
« Reply #28 on: January 14, 2009, 15:19:20 »
test
Ok, so I like a drop !
« Reply #29 on: January 15, 2009, 00:41:38 »
Another test....
Photo failed....Will now try after posting the text...
« Last Edit: January 15, 2009, 00:43:20 by Footski »
