Author Topic: Carbon Fibre  (Read 3169 times)
toesup
  • USA'd Ex Brit
Carbon Fibre
« on: March 11, 2009, 08:30:46 »
I was wondering if anyone had tried using carbon fibre in hull construction rather than FG mat...
Does it need the vaccuum to be successful?...
Does anyone have Ron Dennis's addy?...  :-\
Re: Carbon Fibre
« Reply #1 on: March 11, 2009, 09:01:35 »
HI toesup ; Carbonfibre has problems in the past if you use in saltwater . Just one scatch and it will carode and fail .        puffin
toesup
  • USA'd Ex Brit
Re: Carbon Fibre
« Reply #2 on: March 11, 2009, 09:15:16 »
Thats interesting to know!..
I've found 'failures' in full size boats using CF, but those have been 'stress' related...
I've not come across anything dealing with corrosion...  ???
Re: Carbon Fibre
« Reply #3 on: March 11, 2009, 19:46:26 »
HI toesup; Some of the AMERICA CUP boats had real disasters with mast failing ,just because where they drilled holes in the mast they did not reseal them . When it fails there is no warning it just crumbles . I built  a model sail boat  in the 80's  that was a disaster .                  PUFFIN
Re: Carbon Fibre
« Reply #4 on: March 11, 2009, 23:22:43 »
i know this is diffrent (off topic)  but i used to do a lot of  angling  & have had rods snap like carrots!! as puffin said give you no warning  just snaps
regards ray
