Author Topic: Tamiya Weathering Master B  (Read 6957 times)
« on: May 07, 2009, 18:03:05 »
Hi All:
I bought one of these weathering sets today and I'm just a bit confused on how to use it ???
The instructions say: " Use brush tip to brush powder onto model".
Problem is, the brush doesn't pick the powder up >:(
Should I introduce some thinner, or what??
Has this stuff dried out to the point of being useless?
I'm attempting to add some 'Rust' effect.
longbike
Re: Tamiya Weathering Master B
« Reply #1 on: May 07, 2009, 19:09:01 »
Im not sure of what you got is it a chaulk kit?
If it is you can rub it on with your finger or use a stiff brush and brush it on, try a sample on some scrap.
 Sometime you can scrap up some like with a knife then use your brush.
« Last Edit: May 07, 2009, 19:19:00 by longbike »
Longbike:
Jeff Seemiller
« Reply #2 on: May 07, 2009, 23:27:32 »
Mike,
Could you post a picture of the kit, so we have a better idea.... ^-^
« Reply #3 on: May 08, 2009, 01:35:14 »
john-boy
  • Tugboats are Rock & Roll
« Reply #4 on: May 08, 2009, 01:54:38 »
Tamiya (#87080) - Tamiya Weathering Pastel (Snow, Soot, Rust) [87080]  US$9.00
Tamiya once again takes the lead in modeling innovation with these two Weathering Master sets. Each set contains 3 colors that are specially designed for adding realistic weathering effects to your scale models. Apply directly on top of painted model to achieve dirt, snow, soot or rust-like finish.
About the Sets
Easy-to-control material won£s run into surrounding areas.
Semi-wet compound adheres well to surfaces.
Compact case is easy to carry and use anywhere.
Includes double-tipped applicator brush/sponge-tipped weathering tool.
Use with pre-finished Masterwork Collection models to add your own finishing touches!
Mike, Is this the kit you bought, in there advert they say the product is "Semi wet adheres well to surfaces" if this is not happening possibly past it's sell by date.
John
John
« Reply #5 on: May 08, 2009, 02:29:01 »
Mike,
This product is based on the ladies makeup system and should not need wetting. It should transfer from box to applicator easily, if not in great quantities. I reckon yours has dried up...send it back!!
« Reply #6 on: May 08, 2009, 06:08:28 »
Perhaps for use with another model.....
« Reply #7 on: May 08, 2009, 06:30:21 »
Yup....it's dried out :(
It's not worth returning, so is there anyway I could moisten it up a tad??
pops
    • clayt.com
« Reply #8 on: May 08, 2009, 08:48:13 »
Mike,
Want me to ask my wife how to use it?  ;D
(she's out of town so no danger of her looking over my shoulder and reading this.)
Captain Jack
  • Uniform of the day at sea?
« Reply #9 on: May 08, 2009, 12:50:16 »
So what kind of after coat do you use with this stuff to keep it from rubbing off? I could see using it on a static display than never gets wet, or touched. But for us RC guys, there must be some way to permanently fix it to the surface, right?
Fair winds, and following seas....
Captain Jack sends>>>>>
« Reply #10 on: May 08, 2009, 23:09:24 »
Capt Jack,
Personally I always simply add a coat of matt varnish over the top of all my weathering....Job done :)
