Author Topic: something to tow  (Read 5104 times)
tug of war
Re: something to tow
« Reply #15 on: January 23, 2010, 04:52:45 »
nice job terry ive just spent 20hrs putting the wheel house together some cleaning up to do i found this task very trying so many different angles if it comes out half as good as your model i will be very pleased
tug of war
« Reply #16 on: January 23, 2010, 05:01:18 »
more pics
TERRY
« Reply #17 on: January 23, 2010, 06:07:08 »
It took me about 100 hours to complete the wheelhouse. There are some photos of my Ayton Cross, in modern tugs under the heading model tug Ayton Cross. You may find them of use. Yours is looking good.
Terry.
Measure twice cut once
tug of war
« Reply #18 on: January 23, 2010, 09:21:47 »
WOW MANY THANKS TERRY PICTURES ARE SO HELPFULL SHE LOOKS SO GOOD ON THE WATER A TRULY EXCELLENT BUILD  where did you purchase the korts props and motors . i ve had a look on prop shop but cant make out all the part numbers and what they mean i was thinking about having a single steerable kort maybe 90mm any thoughts on that
« Reply #19 on: January 23, 2010, 12:16:28 »
This is a model of the Ormesby Cross sister of the Ayton Cross I built her in 2007,she makes into a very powerful tug.
« Last Edit: January 23, 2010, 12:19:43 by chipchase »
TERRY
« Reply #20 on: January 24, 2010, 04:21:58 »
Hi Tug.O.W. I should build her as twin screw, as is the full size tug. The korts are 70 mm steeable korts from MMM, the props are 65 MM four blade kort props, from the Prop Shop. This works out pretty much to scale. I used a motor mixer from Action electronics, and a 32 MM Marx Luder bow thruster.The motors are car heater type, also from MMM. She is very powerfull,  agile, and a pleasure to sail. Bryan at MMM, is always very helpfull, and will advise you on running gear.
Terry.
tug of war
« Reply #21 on: January 24, 2010, 07:47:53 »
again many thanks terry your tugs really look the part on the water
