Author Topic: Tugboyben's Smit Nederland  (Read 40704 times)
Kieran H
Re: Tugboyben's Smit Nederland
« Reply #45 on: February 04, 2010, 18:09:28 »
good info going around.
« Reply #46 on: February 05, 2010, 13:04:14 »
hi all
been busy with the korts thank you all for the ideas & pictures some pictures of wot i have come up with  ;)
jason
« Reply #47 on: February 05, 2010, 13:05:27 »
« Reply #48 on: February 05, 2010, 13:06:41 »
sea.mariner
  • I Know a fair bit about tugs but am always learning !
« Reply #49 on: February 05, 2010, 13:15:38 »
Looking better Jason  :) What did you use for the 'filler'' and I could recommend a 4 blade propellor which will be more efficient and gives more thrust.
Regards, Dan.
ps, obviously for the maximum thrust possible from a kort nozzle, you would need kort props, depending on the diameter you are left with within you kort nozzle you may need to order props or if you are lucky you could find some to fit perfect  :)
Photos / Information, I nearly have them all !
« Reply #50 on: February 05, 2010, 13:24:39 »
hi dan
my plan is to get a pair 4 blade kort props i will get some 50mm props in the korts as the copper pipe is 55mm (dia) if some one as some for sale they need to fit a M4 shaft the filler is car body filler with a strip of 5mm by 10mm plastic card
thanks jason
« Last Edit: February 05, 2010, 13:28:06 by tugboyben »
sea.mariner
« Reply #51 on: February 05, 2010, 13:33:52 »
I am sure you are aware of the range of Kort props sold by the PROP SHOP ;
http://www.prop-shop.co.uk/index.php?id=32&section=store&sub_section=products&product_type=32
Also cornwall model boats ;
http://www.cornwallmodelboats.co.uk/acatalog/raboesch-4bladed-kort-prop.html
etc, etc, the choice is endless  :) :)
Good luck and let us know what you choose  ;)
Regards, Dan.
« Reply #52 on: February 05, 2010, 13:46:54 »
Looking good Jason, exhalent work on your nozzles. I bought two 70mm 4 blade kort props from prop-shop, not cheap at 60 but exhalent quality (you only get what you pay for)
« Reply #53 on: February 05, 2010, 13:48:02 »
hi dan & brian
thanks i will let you no i would like to go with prop-shop ones we will see
jason
« Last Edit: February 05, 2010, 13:53:08 by tugboyben »
lightshipman
« Reply #54 on: February 27, 2010, 16:48:08 »
Your certainly a prolific builder, progress looks good, and high quality.
Andy
Keeping the Bristol Channel safe
Nav Aids Tender Skipper
« Reply #55 on: March 21, 2010, 10:17:14 »
hi andy
thanks i have not done much got it back out of the shed today & add a few hours a few pictures
jason
« Reply #56 on: March 21, 2010, 10:42:24 »
Good to see the progress Jason :) :)
Now that the weather's a bit better.........
...Cheers...
« Reply #57 on: March 21, 2010, 11:12:51 »
hi tugs53
yes it is nice to have the sun again can get some painting done now  :) :)
jason
« Reply #58 on: March 21, 2010, 11:36:38 »
You've given me the inspiration to get on with my Smit Ned 're-build' project.
I've been working on a couple of other tug projects...yet to be announced :-X :-X
sea.mariner
« Reply #59 on: March 21, 2010, 11:45:30 »
Mike, I think it is time to disclose your secret projects  :) :) :)
Regards, Dan.
