Author Topic: New from MMB  (Read 14814 times)
tango
New from MMB
« on: March 21, 2010, 08:44:10 »
We have just started to produce our own prop shafts featuring stainless steel outer tube 6mm diameter and stainless steel 4mm shaft threaded one end or both ends. Bearings are made from hard wearing PTFE and are virtually maintainence free and come with stainless steel lock nuts and washers..
Lengths kept in stock range from 5" to 10" but other lengths can be made to order.
See website http://marksmodelbits.com/ for prices or call 01633 431010 for mor info.
As a side note would there be any interest in a range of M2 propshafts with a 4mm outer tube?
Mark.
« Last Edit: August 03, 2010, 01:42:35 by tango »
tango
Re: New from MMB
« Reply #1 on: March 26, 2010, 02:12:03 »
Hi guys, we have started producing resin cast fittings, the range is constantly being added to and we will be making fittings in the most popular scales.
They are supplied unfinished but only require a light clean up and some will need some construction.
marksmodelbits.com
Mark.
tango
Re: New from MMB
« Reply #2 on: June 25, 2010, 02:12:59 »
Hi all, we are still slowly adding to our range of resin fittings in between doing everything else!!
Here we have 3 enclosed array radar scanners.
The small, low profile scanner measures 19mm diameter x 13mm high.
The large, low profile scanner measures 26mm diameter x 17mm high.
The large, standard scanner measures 35mm diameter x 28mm high.
They are priced at 1, 2 and 3 each respectively +P&P.
More will be following soon.
marksmodelbits.com
mmbshop@hotmail.com
Or tel. 01633 431010
Mark.
tango
Re: New from MMB
« Reply #3 on: August 03, 2010, 02:08:58 »
The MMB Skunkworks is pleased to announce the release of some new fittings.......
First up is a modern, electric powered capstan, cast in resin.
Priced at only 7.00 plus shipping.
Next up is a modern style electric powered anchor winch comprising of cast resin and brass parts.
This is only 11 plus shipping.
Finally for the moment we have a rope fender kit containing 1x bow fender, 1x stern fender and 8x side fenders, these are hand made from natural coloured, 100% cotton and have fixing chain sewn in.
This is only 8.00 plus the dreaded P&P!!
More details are on my website marksmodelbits.com  or call me on 01633 431010.
Mark.
tango
Re: New from MMB
« Reply #4 on: September 19, 2010, 11:57:06 »
Well we have been busy again at the MMB Skunkworks...
We now have a range of fixed and steerable kort nozzles.
Cast in very strong "drop it and it will bounce" Polyurethane resin.
The sizes available are....
45mm  10 fixed & 11 steerable
50mm  11 fixed & 12 steerable
60mm  12 fixed & 13 steerable
70mm  13 fixed & 14 steerable
All prices plus P&P....
marksmodelbits.com
Or call me on 01633 431010
« Last Edit: November 05, 2010, 00:41:18 by tango »
tango
Re: New from MMB
« Reply #5 on: September 26, 2010, 14:13:59 »
Well there is no rest for the MMB Skunkworks.........
We now have available an open lifeboat measuring 4 1/2" long 1 3/4" beam and 1 1/8" high
The hull is moulded in light weight GRP and includes resin castings for the seats and floor grating.
Price is 6 + P&P each
marksmodelbits.com
Or call on 01633 431010
tango
Re: New from MMB
« Reply #6 on: November 05, 2010, 00:52:45 »
Hi from the MMB Skunkworks, we now have available some more fixed & steerable kort nozzles.
40mm 9 fixed & 10 steerable
80mm 14 fixed & 15 steerable
90mm 15 fixed & 16 steerable
Mark.
tango
Re: New from MMB
« Reply #7 on: December 18, 2010, 01:11:57 »
Hi all, right, I know this isn't a tug but..............
The MMB Skunkworks has been working flat out on our latest project....
A set of mouldings for a Los Angeles class submarine consisting of hull, deck & sail moulded in GRP. Dive planes, rudders, stern extension cone & periscopes cast in polyurethane resin.
The deck and sail has all the hatch details moulded in and the dive planes and rudders have stainless steel control rods cast in as an integral part of the fitting.
The hull is 53" long (inc stern cone) & 5" beam.
Price is 150 + P&P
Dive plane, rudder, stern cone & periscope set.
For more info or shipping costs call 01633 431010 or email  mmbshop@hotmail.com
Mark.
tango
Re: New from MMB
« Reply #8 on: January 21, 2011, 13:34:07 »
Hi Guys & gals, I have sourced a voltage converter to power my Foggy smoke generator from a 12 volt battery.
Mark.
« Last Edit: January 21, 2011, 13:37:32 by tango »
tango
Re: New from MMB
« Reply #9 on: April 15, 2011, 07:36:54 »
Well have been busy at the MMB Skunkworks!!!
First off we have an early style deck/cargo winch.
Base 49mm x 42mm. Narrowing to 30mm
Width across warping drums 55mm
47 mm high.
Next we have an early "Furuno style" enclosed radar scanner.
This measures 34mm diameter and 19mm high
Price 1.80 +P&P
Last for the moment a transom end open lifeboat moulded in GRP complete with a seat and floor grating cast in polyurethane resin.
This measures 150mm long and 56mm beam.
Price 8.00 +P&P
More info at marksmodelbits.com or call 01633 431010.
Mark
tango
Re: New from MMB
« Reply #10 on: May 21, 2011, 14:59:28 »
The MMB Skunkworks has been burning the midnight oil and as a result we have some new fittings available.....
First up a compass/binnacle........
Pedestal measures 11.5mm diameter.
Width across top 24mm.
Total height 42mm.
1.50 + P&P
Next we have a compass with pelorus stand mounted on base....
Base measures 21.5 x 27.5 mm diameter.
Total height 47mm
2.00 + P&P
Next we have a Sampson post........
Base measures 16mm diameter.
Diameter 11mm.
Total height 53mm.
0.60p + P&P
And last but by no means least covered air vents in 2 sizes..........
Small one:
Measures 10.5mm diameter by 25mm high.
0.50p + P&P
Large one:
Measures 16.5mm diameter by 40mm high.
1.00 + P&P
Watch this space for more stuff coming soon.....
Mark.....
« Last Edit: May 21, 2011, 15:19:52 by tango »
tango
All new from MMB!
« Reply #11 on: August 02, 2011, 03:51:06 »
We have two new releases at MMB today :-)
Firstly, we have a smaller scale version of our lobster pots (Creel), measuring 40x30mm. Kit comes with resin base plate, wire for the frame and netting. Price is 2.50
Secondly we have another smaller scale version of our glassfibre lifeboats. This one measures a tiny 3" long, and comes with a resin cast seat and floor grating. The price for this one is just 5
« Last Edit: March 12, 2013, 11:06:36 by tango »
TugMaster
  • Administrator
  • Welcome Aboard !
Re: All new from MMB!
« Reply #12 on: August 02, 2011, 04:30:22 »
Wow ! Bargain !
Ok, so I like a drop !
tango
« Reply #13 on: August 05, 2011, 10:55:57 »
Three new lobster pots for you all today - We've been busy!
Extra tiny ones, 27mm by 15mm. Round or square tops. 2 each
Large round topped ones, same size as our current large one, 75mm by 45mm. 3.50 each
tango
Re: New from MMB
« Reply #14 on: September 17, 2011, 10:45:21 »
Our new range is 1:32nd scale doors, and have a nice little added touch of a raised handle.
First, we have a watertight door with a single handle.
Second is a watertight door with six dogs.
Third is a pair of bridge doors, port and starboard.
Lastly we have a pair of doors with portholes, port and starboard.
All are 1 each, or 2 for a paired set.
Mark
« Last Edit: March 12, 2013, 11:28:19 by tango »
