Author Topic: AHTS. Maersk Master scale 1/50.  (Read 48479 times)
Re: AHTS. Maersk Master scale 1/50.
« Reply #60 on: June 11, 2011, 09:17:43 »
First Class!!!!
« Reply #61 on: June 12, 2011, 11:57:49 »
Fantastic workmanship M Trader, bring her to Balne Moor and she will be really put to the TOWING test. ;D ;D ;D
« Reply #62 on: June 12, 2011, 12:29:59 »
wow i am so impressed that is fantastic work :o :o.
« Reply #63 on: June 13, 2011, 10:14:43 »
Like John say's...fantastic workmanship!
« Reply #64 on: June 13, 2011, 17:20:42 »
Leen,
Do the ASD drives work syncronised with the rudder or are they all independently controlled?
M.Trader
« Reply #65 on: June 14, 2011, 00:08:48 »
Hi steve.
The Azimuth thrusters are separate to controle by this two controle units.
I can control the Azimuths over about 380 degrees (not endless)
The ESC workes forward and backwards.
At the photo you see the old MC 19 transmitter, now I use the MC 22 and I programmed the position of the THR to the position of the rudder.
And by full rudder to port, the port THR will turn about 75 degrees and the startboard about 45 debrees
also the ESC of the THR are programmed with the position of the Pitch.
I use a self made Controlled pitch propeller, by pulling th estick forward the pitch will change position and the ESC of the THr will control the THR motors.
The speed of the main Propeller will turn always full RPM.
But also this function is mixed so the model is better to control.
I will try to made a video to show how it works.
This photo shows, the zero pitch and full ahead.
http://www.youtube.com/watch?v=uY6QAl_BSpQ
gr leen
« Last Edit: June 14, 2011, 01:46:57 by M.Trader »
« Reply #66 on: June 14, 2011, 14:59:24 »
Very clever. You have certainly set a new benchmark in every respect.
M.Trader
sailing at the Dutch modelling club SMG IJmond
« Reply #67 on: July 09, 2011, 03:44:32 »
Hi.
Some photos of sailing by the SMG IJmond modelling Club.
Also The M@il-line with the new rebuild M@il-line Lifter where sailing.
I hope you enjoy the photos.
http://www.youtube.com/watch?v=VxCl-Y4_9-s
http://www.youtube.com/watch?v=xeQdN-KAMMA
« Reply #68 on: July 09, 2011, 05:58:35 »
Amazing detail - on all of them!
« Reply #69 on: July 09, 2011, 06:24:48 »
The detail in these boats kinda makes you feel third rate.  4th?  5th?  6th?  rate.
                                 Norm
« Reply #70 on: July 09, 2011, 09:24:51 »
NOW THAT"S OVER THE TOP ON DETAIL .              PUFFIN
« Reply #71 on: July 09, 2011, 09:30:39 »
Absolutely incredible workmanship :) :)
« Reply #72 on: July 09, 2011, 14:44:19 »
Fantastic models Leen, it must be great to be involved with so many AHT enthusiasts to exchange ideas.
