Author Topic: LED wiring diagrams  (Read 5293 times)
Triton
LED wiring diagrams
« on: January 02, 2011, 19:57:18 »
Hi,
Check out this link:
http://led.linear1.org/led.wiz
Put in the values (typical forward voltage for LEDs is 2.5V, forward current 20mA), select "wiring diagram", click on "design my array" and it'll come up with a suggested wiring diagram(s) plus resistor values for any combination of supply voltage/number of LEDs.
Hope you find it useful,
John
« Last Edit: January 02, 2011, 20:00:09 by Triton »
Tugboat Rog
  • Don't stop playing when you get old, you get old when you stop playing!
Re: LED wiring diagrams
« Reply #1 on: January 04, 2011, 05:32:36 »
I can cofirm that this site is very good, as it is the one I used when doing the wiring of the LED's for my Eurogirl tug. Alll working modern tug navigation and toingw lamps, which took a bit of working out on the wiring using a 12V supply. :o
Regards,
Roger S.
MaxieGodde
« Reply #2 on: March 06, 2012, 22:28:11 »
HI ALL ; HELP, HELP, HELP . I want to put on my tug ,leds lights for navigation and led strip lighting outdoor 12v led light bars led strip lighting running lights  . If asome body could help me , would be apprecitated . What is the best power source to use ,and a wiring diagram .
