Author Topic: Svitzer milford fleet  (Read 11922 times)
tees g
« on: February 13, 2011, 04:38:02 »
 ANGLEGARTH. built by Damen 1997 in Holland. ASD. Now moved to Greenock.
                       LOA.32.7    Beam.11.8   Draft.5.1  speed .13.5  Grt 374.
 MILLGARTH.  Built by Damen 1997 in Holland ASD. Now working at Gravesend.
                   30 x 11 x 5.5m speed. 13.5 Grt74  BHP..5100 FiFi
                   MMSI.232002697    IMO. 9414122. Callsign. MW156.
« Last Edit: March 10, 2011, 05:40:55 by tees g »
tees g
Re: Svitzer milford fleet
« Reply #1 on: February 13, 2011, 04:56:26 »
New builds laying at new moorings
tees g
« Reply #2 on: February 13, 2011, 07:19:02 »
 DALEGARTH... ex Kestrel built 1985 Hanzaki Japan for  J P Knight.  Now working Swansea.                      ASD.  LOA..36.30    BEAM..10.80    DRAFT..4.40.   GRT..360   BP..40t bow  /45t stern. SPEED..13.5.
 THORNGARTH... built 1983 Hanzaki Japan poss Knigths tug ? Now workingAvonmouth.     ASD.
 Details same as DALEGARTH.
Anglegarth. Millgarth, Dalegarth, Thorngarth are the old Milford fleet.
tees g
« Reply #3 on: February 13, 2011, 08:24:54 »
SVITZER MILFORD. bUILT 2004  M class tug. now working Greenock.
                             LOA.. 27.4  BEAM.. 11  DRAFT.. 4.6  GRT..366 SPEED...12.5 knts.
                             BP..60T.  BHP.. 4.840..
                             Main Engs,...2 Mak 6 U25 ....1800Kw.
                             Props,......2 x Aqua-master cpp us 205cp.
   The above fleet has now being replaced by a more powerfull fleet of spanish newbuilds.
« Last Edit: February 23, 2011, 05:19:14 by tees g »
« Reply #4 on: February 13, 2011, 13:54:18 »
These are great pictures!!!
« Reply #5 on: February 13, 2011, 14:08:49 »
As far as my own archives go, the THORNGARTH was never in the hands of JP Kinghts ;
THORNGARTH (ex TENZAN-91) one of Svitzer's Japanese-built ASD tugs (bollard pull: 45 mt). IMO number: 8311998. Gross tonnage: 365. Completed: 1983-09 by Hanasaki Zosensho K. K., Yokosuka, Japan (yard no: 191). Dimensions: loa. 36.3 m b:10.0 m draught: 3.2 m. Main engine(s): 2, Niigata 28BXE diesels. Power: 2,502 kW. Speed: 14.0 kn.
tees g
« Reply #6 on: February 23, 2011, 05:47:07 »
Todays new Milford fleet. No 1   Svitzer Kilroom.
                        IMO....9440904.   MMSI....235066353.
                        Keel laid...06/ 06/ 2007. Delivered...2008
                        Length....39.71 m   Beam...14.70m  Draugth...4.81 m.
                        Gross ton...819ton.    Nett ton...245ton.
                        Speed...15.7. Bollard pull ahead....113ton.   BP, astern 107ton.
                        Main Engs,  2 x  Gen, Elec, 2 x 30445 kw.  1050rpm.
                        Props, .....2 x  Schottel   187rpm.
tees g
« Reply #7 on: February 23, 2011, 06:22:43 »
 No2  Svitzer Linsway.    IMO...9440758     MMSI....23506601.     ASD.
                                     Built 2008   Length..34m  Beam..14m Draugth...7.4.
                                    Bollard pull 96ton.
tees g
« Reply #8 on: February 23, 2011, 06:53:19 »
     No 3 Svitzer Geliswick. ASD. Callsign...2AXZ5.
                                        MMSI....235063849.   IMO....9412373.
                                        Keel laid 2007   Deliv, 2008.
                                        Length.32.6   Beam...11.6    Draught ..4.5
                                        Gross Ton,...490.    Nett, Ton,...147.
                                        Speed...13.4  Bollard pull ahead...88ton. astern ..79ton.
                                        Main Engs, 2 x Niigata 2206 kw.   750rpm.
                                        Props,  2 Niigata..ZP41.    220rpm.
tees g
« Reply #9 on: February 23, 2011, 08:05:31 »
 No 4  Svitzer Musselwick .  ASD. MMSI 235063852. IMO. 9412385. Callsign 2AXZ7.
 No 5  Svitzer Watwick.    ASD.    MMSI 235063854  IMO. 9412397  Callsign. 2AX29.
 Both these boats are the same size, engs, as Svitzer Gelliswick.
 On the  19 May 2010 all five tugs ,and the two line boats Svitzers, Thaw. Taku.
 Where officially named.
 These five tugs I think are working the South Hook LNG jetty.
tees g
« Reply #10 on: February 23, 2011, 09:14:15 »
No 6 SVITZER CALDEY  ASD, Callsign ZBPD3. MMSI..235068112. IMO..9440887.
No 7 SVITZER RAMSEY . ASD. Callsign...2BPD2  MMSI235068109. IMO...94408
Same details as Sitzer Gillwick.
tees g
« Reply #11 on: February 23, 2011, 09:32:38 »
 No 8  SVITZER WATERSON. Callsign..2AXK6.  MMSI.235063728. IMO.940760  BP 95 Ton.
 No 9 SVITZER HAVEN.  Callsign...2Bos5..   MMSI.23567991.  IMO.944060 . BP 95.ton.
 Same details as Svitzer  Linsway,only diff,is  BP 96 ton.
tees g
« Reply #12 on: February 23, 2011, 10:06:15 »
 No 10 SVITZER PEMBROKE. ASD. FIFI 1.(2400m 3/h ) Water/ Spray. Callsign...2DDS8.
                                         MMSI. 235078115.  IMO.9557927. Keel laid Aug,09 Deliv, 2010.
                                         Length.35.8m   Beam.14.5m Draught. 7.5m.
                                         Bollard pull ahead..100 ton. astern..90 ton .  Speed...13.5 knots.
                                         Main Engs,.. 2 Gen, Elec, 3045 kw . 1050rpm.
                                         Props,.....2  Schottel  187rpm.
     Svitzer Pembroke is covering the MILFORD  fleet ony for short time , and then to by used in
     coastal work.
tees g
« Reply #13 on: February 23, 2011, 10:57:05 »
     No 10 ?  WARRIOR III.
                                      MMSI. 250105760.  IMO. 7501364,  cALLSIGN E1MY.
                                      Length...27m   Beam....9m   Draught...3.5m.
                                      2x Z Drive fix pic, props,  Fixed   Kort Nozzles.
                                      BHP...2600    Bollard pull 35 ton.
                                      Built June 1975. Worked the Clyde till moving down to Millford .
                                      A few years ago.
                                      Seen here along side the SVITZER KILROOM
                                      Warrior III. is poss,to be moved on , sold. ?.
« Last Edit: February 24, 2011, 05:47:43 by tees g »
tees g
« Reply #14 on: February 23, 2011, 11:14:06 »
  I think the last pic, of the Warrior along side the Kilroom has been air brushed.
 Never seen blue skys all the times  I have being there only rain ?
 All pics of Milford  are by  kind premission of Steve Kerrison. master of Caldey.
 Thank you steve  great pics.
