Author Topic: settling on the tug/tug aquired  (Read 24884 times)
chrisuk
« on: March 05, 2011, 14:25:12 »
Well i no i have said this before, but i think i will get this tug an not sell it in a few weeks. Iam waiting on the chap who is selling it to get some more pictures for me to have a look at, an try an pick it up Tuesday when i pass by. I am happy to try an tidy it up, if it needs it?
I am looking at settling on the 1/50th scale at the moment, but would really appreciate an information about the tug. I can make out what looks like intrepid, but looking online iam finding a US aircraft carrier with Concorde on???
Any relative information, or direction would be much grateful
« Last Edit: March 10, 2011, 09:59:36 by chrisuk »
chrisuk
Re: settling on the tug
« Reply #1 on: March 07, 2011, 14:10:57 »
Well the tug looks to be mine, with a collection tomorrow. Looking at the views with not many posts iam guessing that not many no what its based on :(
Not to worry somone may find out, or i will
Norry M
« Reply #2 on: March 08, 2011, 02:47:42 »
...Hi Guys...
One of the easiest ways of finding what scale a model is built in is to measure the size of the doors...Then  calculate the scale from there...
...Best Regards...Norry
Get Yir Tugs Oot Furri Bouys
mersey dave
« Reply #3 on: March 08, 2011, 03:46:03 »
That would be one hell of a size aircraft carrier for concord to land and take off. ??? ???
Regards Dave.
Sudbury II
« Reply #4 on: March 08, 2011, 08:41:20 »
Good luck with your purchase; and please post some pics when you get it!
Suds
"Suds"
chrisuk
Re: settling on the tug/tug aquired
« Reply #5 on: March 10, 2011, 10:15:26 »
Well i no have the tug taken the pictures an the info is as follows,
The doors are 42mm high
Windows 10x15mm
Hand rails on the bridge 20mm
Rails on AFT deck 50mm
Tyres 40mm to 50mm
RIB 150mm
The pictures,
will let you no how it goes when i find out how low i can go to lower it into the water ;D
So iam still not sure off the scale, or any idea what its based on ???
chrisuk
« Reply #6 on: March 10, 2011, 10:41:57 »
just can only get one motor to fire up grrr
poll
« Reply #7 on: March 10, 2011, 11:14:15 »
Hi Chrisuk.  Have you tried  power straight to the motor, but it looks burnt out to me.
John
Cragsider
« Reply #8 on: March 10, 2011, 12:14:25 »
John
I would say it definatley is burnt John, A squick sniff inside the hull should confirm it.
If you are confident with an electric Multi-meter/tester, set it for Amps DC, connect it in series with the offending motor and see if it has an amp draw when operated.
Alternatively disconect the motors from their supply (Important to do this, as your tester wont like supply voltage up it, when checking resistance or continuity) set your meter for resistance and just check the resistance across each motor, see if you have a wildly varying reading between motors, or even a closed or open circuit which will confirm the motors up the swannee.
Peter.
« Last Edit: March 10, 2011, 12:17:26 by Cragsider »
Peter.
chrisuk
« Reply #9 on: March 10, 2011, 12:25:11 »
I dont have one off these let alone no how to use one ;D
your right it does look  >:D not a good start found a few broken wires as well
suppose you get what you pay for
« Reply #10 on: March 10, 2011, 13:24:34 »
Hi Chris what size is your new AHT
chrisuk
« Reply #11 on: March 10, 2011, 13:30:17 »
Sorry its 55inches long with a beam 13inches wide. or 1400mm x 330mm  ;D
so it is big just like i always wanted  :) :)
just a bit big to go any where so its back in its house the boot an rear seat folded down - the car  ;D
chrisuk
« Reply #12 on: March 11, 2011, 08:53:09 »
Also my korts are around 55mm diamiter an 20mm long the props 45-50mm so these are a bit small an need upgrading i would say. so this would not help my motor issue as i will just burn them out
mersey dave
« Reply #13 on: March 11, 2011, 09:14:36 »
Your motor will not burn out if the props are a bit small, it works the other way props that are to big demand to much from the motor hence they burn out.
Regards Dave.
chrisuk
« Reply #14 on: March 11, 2011, 09:57:29 »
oh ok, thanks. what props/korts should i have on a model off this size? an motors?
