Wanted to post my first build thread on the forum. Have done several before on other forums but felt this was the best place to get good criticism and advice on tugs. Purchased a Bandera hull from a friend a couple months ago and decided on a new theme for the boat. The original hull is about 37" x 12" so I scaled it for a 1:12 model. Did some side view renderings to get a nice proportion between the Bandera hull and a new superstructure. As you can see, It has a lot of SeaImp and Mckenzie feel to it.
I decided to keep the original kits dual nozzle setup and 3" kort nozzle props. Nozzles are cast aluminum, shoes are solid bronze and the props are a brass alloy from Prop-Shop. This thing is going to be beefy.
Got 2 of the infamous "Big Pittman" motors running a direct drive setup. Electronic plans are independent motor control, lights and a smoke system. Model will eventually get a custom winch and a sound unit when I find one that is worth the $$$$$. More pics coming tonight.
D
Red line is estimated deck location...
