Author Topic: Rebuilt project from Smit Enterprise to Bergingshaai 2  (Read 56578 times)
zeevaart1
  • www.bergingshaai.nl
« on: August 08, 2011, 04:47:39 »
Hello builders.
Here a start with a rebuild tugboat.
I'm already one year busy with the rebuilding.
So the pictures will come a litle faster.
So he looked,when I bought it.
Size 185x45 cm
Scale 1:25
First I start with taking out of the old electronics
View of the stern.
Breaking off the old stern
The new stern in progress.
The new aluminum sternroll with bearings
« Last Edit: August 08, 2011, 05:38:58 by zeevaart1 »
with best regards Cor
www.bergingshaai.nl
Re: Rebuilt project from Smit Enterprise to Bergingshaai 2
« Reply #1 on: August 08, 2011, 07:33:50 »
Beautiful model there. Lets have more please!  :) :)
zeevaart1
« Reply #2 on: August 08, 2011, 09:35:39 »
Thank You Barry.
there is more coming.
Here I start with the new becker rudders.
a lot of milling work.
Already two pieces of rudders for fifty percent finist.
The backflaps in progres.
Here I have rounded the hinges.
example how it should becomming.
guiding for the backflap in parts.
two rudders ready,and waiting for work.
This is the wingsupport for between de nozzles.
soldered and cleaned.
Breaking off the old nozzles and rudders.
alignment from the nozzles.
The difference between,two props from 120 mm to 108 mm.
result.
view,how it should be.
made foundation for the nozzles and rudders.
This is the new backwall of the winchroom.
wire protection.
Towingdisc.
finished the backwall with towindisc and wire protection.
Here I start with the new workingdeck.
Making holes in my new workingdeck.
see if it all fits.
Here I start with de new working floor.piece by piece.
« Last Edit: August 08, 2011, 11:00:54 by zeevaart1 »
www.bergingshaai.nl
« Reply #3 on: August 08, 2011, 09:42:37 »
Looking forward to your rebuild.
zeevaart1
« Reply #4 on: August 08, 2011, 11:08:34 »
have patience,but thank you Tug Man
halfway with the new floor.
Finished with the floor.600 pieces.
« Last Edit: August 08, 2011, 11:13:44 by zeevaart1 »
www.bergingshaai.nl
zeevaart1
« Reply #5 on: August 08, 2011, 11:15:47 »
Making towingpins.
Placing the towingpins.
Making of two cargo/crashrails.
Wire catchers.
« Last Edit: August 08, 2011, 11:26:43 by zeevaart1 »
www.bergingshaai.nl
« Reply #6 on: August 08, 2011, 11:48:14 »
WOW :o that is some rebuild keep pictures coming.
Very nice :).
regards John B
zeevaart1
« Reply #7 on: August 08, 2011, 12:28:50 »
Very nice :).
regards John B
Thank you very much for the compliments Tugnut.
Take out of the old foundation.
« Last Edit: August 09, 2011, 07:14:05 by zeevaart1 »
www.bergingshaai.nl
« Reply #8 on: August 09, 2011, 01:51:49 »
Superb.... :)
zeevaart1
« Reply #9 on: August 09, 2011, 07:15:16 »
Superb.... :)
Thank you again Barry.
Making a new foundation for de engine's.
New bearings in parts.
The new foundationplate with holes for the propulsionline.
Two gearboxen one fineshed and one in parts.
One propulsionline complete.
Both propulsionline's fineshed.
Movie test run engines,start on 3 volt and powerup to 12 volt
http://youtu.be/HrAicyszQvI
Finished painting the reardeck also put the rudders in place.
Making a new bowfender from a belt.
I fill the holes with liquid rubber.
The old lifeboad was no longer good so we orded a new one,at the shipyard,
New FRC (fast resque craft) in progres.
The new FRC finished.
FRC on board.
FRC out board.
FRC on the waterline.
launch david for the FRC.
making two pendant bouy's for the anchor's.
Splice steelcable and put A clamb on.
I have made a delta flipper anchor.
Also I made a drag anchor.
view anchor's.
View anchor's with steelcable and pendant bouy's.
New radar's.
my own design new headmast.
new lights.
All stanby in the primer.
Starting with the new foundationdeck for the wichroom.
The new engine's for the winche's,with a gearbox 810:1,
All the parts for the winche's.
First I put the wire on the drum.
View of the drum.
Making sockets for the towing and anchorhandling wire's.
Put the wire's on the drum's.
Testing socket's,20 KG and holding.
Put the drum's on the plate,with the belt.
Put the winches in the winchroom,time for testing.
Movie winch pulling test 8,5 KG.
http://youtu.be/DsBgKX1ULGM
movie winch test acros the sternroll 11,5 KG.
http://youtu.be/TpsDyr04Y44
movie pulling delta flipper anchor on deck.
http://youtu.be/kbUK1kdCgWk
movie pulling drag anchor on deck.
http://youtu.be/xGdPVEM28O0
Time for making the towingear.
Making a stretcher.
Make a eye in the stretcher.
Finished the stretcher.
Deltaplate/monkeyface.
View reardeck with towing gear.
Here I start a new project,making a new crane.
foundation adjustment.
Start with the base of the crane.
Crane base in parts.
looks almost the same.
« Last Edit: August 10, 2011, 03:21:26 by zeevaart1 »
www.bergingshaai.nl
« Reply #10 on: August 10, 2011, 22:12:28 »
Wow
zeevaart1
« Reply #11 on: August 10, 2011, 22:37:43 »
Wow
Sea monkey, greate name  :)
One word can say more than thousand pictures.
thank you.
« Last Edit: August 10, 2011, 22:42:55 by zeevaart1 »
www.bergingshaai.nl
« Reply #12 on: August 11, 2011, 02:03:51 »
 :o :o :o :o
zeevaart1
« Reply #13 on: August 11, 2011, 03:29:20 »
:o :o :o :o
I can only say thank you.
The first boom.
Hand in hand.
Front or rear view ::).
View of his new position.
what am I doing wrong here.
If I put pictures on they'll be in a blue box.
Footski help.
« Last Edit: August 11, 2011, 03:43:25 by zeevaart1 »
www.bergingshaai.nl
zeevaart1
« Reply #14 on: August 11, 2011, 03:49:32 »
it seems a bit too long.
But that's easy to adjust.
better long than too short. :)
« Last Edit: August 11, 2011, 03:55:57 by zeevaart1 »
www.bergingshaai.nl
