Author Topic: TID 164 Build  (Read 55321 times)
ARH
Re: TID 164 Build
« Reply #30 on: November 20, 2011, 02:13:21 »
Well son, From what ive seen of your build, its going to be another classic.
You have not lost your touch for turning out good work even with a long lay off. :) :)
ARH
Re: TID 164 Build
« Reply #31 on: November 21, 2011, 02:39:34 »
How the superstructure fits over the boiler and the funnel,  :) :)
Tiny69
Re: TID 164 Build
« Reply #32 on: November 22, 2011, 12:59:17 »
I have been working on the hull starting with the off set anchor portal in the bow and then a second coat of primer on the superstructure ready for yet more sanding.
Anthony
Tiny69
Re: TID 164 Build
« Reply #33 on: November 22, 2011, 13:03:02 »
Anthony
Re: TID 164 Build
« Reply #34 on: November 22, 2011, 14:17:57 »
Looking good Anthony.
Tiny69
Re: TID 164 Build
« Reply #35 on: November 23, 2011, 10:30:19 »
Thanks Suds,
Been doing some more work on it this week, mainly on the superstructure and some deck fittings.  Will upload some more photographs of my progress soon.
Tiny
Tiny69
Re: TID 164 Build
« Reply #36 on: November 28, 2011, 10:31:51 »
As promised a few more photo's.  I have given the superstructure a bit of colour.
Tiny
ARH
Re: TID 164 Build
« Reply #37 on: November 28, 2011, 15:24:57 »
Begining to take shape.  :) :)
Re: TID 164 Build
« Reply #38 on: November 28, 2011, 19:57:49 »
I'll second that!!
Suds
Tiny69
Re: TID 164 Build
« Reply #39 on: November 30, 2011, 10:23:17 »
Here are some more photo's showing the front of the superstructure tanks and the steam plant.
Tiny
Tiny69
Re: TID 164 Build
« Reply #40 on: November 30, 2011, 12:55:10 »
Started building the windlass from the drawing I produced on AutoCAD.  Some old gears, 3mm diameter shafts, copper tube for bearings and some platicard for the brake housing.
Tiny
Re: TID 164 Build
« Reply #41 on: December 01, 2011, 08:43:07 »
With that much detail; you could make the winch operational.
Looking good Tiny!!
Tiny69
Re: TID 164 Build
« Reply #42 on: December 01, 2011, 11:31:29 »
The objective is to make a working replica even though in reality the full size windlass is hand operated.  All the gears mesh together and are a tight fit on the shafts so hopefully they should all rotate.  This is the beauty of working at 1:24 scale.  The next step is to build the windlass structure to mount everything on.
Tiny
Tiny69
Re: TID 164 Build
« Reply #43 on: December 04, 2011, 02:18:03 »
Some more progress on the windlass. Just the warping drums to add.
Tiny
Tiny69
Re: TID 164 Build
« Reply #44 on: December 06, 2011, 11:30:56 »
Two fairleads made from 25 x 5mm brass strip soldered togther.
Tiny
