Author Topic: New boys first scratch build  (Read 11969 times)
Timo2
  • A buoy at heart
« on: September 12, 2011, 11:39:10 »
Hi All
       My first time to try a scratch build   :-\
       A friend gave me a few photos of a channel tug he saw on holiday, and said you think you can build one  :o  Lets start Pencils, rubber,Paper, drawing board, ruler, think that the lot.
 Photos
Timo2
« Last Edit: September 14, 2011, 22:29:34 by Footski »
Just a Buoy at heart.
Timo2
  • A buoy at heart
Re: New bouys first scratch build
« Reply #1 on: September 12, 2011, 11:46:36 »
More
Umi_Ryuzuki
    • Models and Miniatures
« Reply #2 on: September 12, 2011, 20:16:14 »
Perfect canidate for a Springer hull.
« Reply #3 on: September 12, 2011, 20:38:43 »
that works for me - next springer I'll remove the slight curve in the deck - well proportioned model -
Timo2
  • A buoy at heart
« Reply #4 on: September 13, 2011, 00:04:14 »
Hi and Thank you
   Aimee and Mike on not a Springer ,I have a very hard working Springer over 100 hours run time this year so far .
    Chame11 will go for a Semi Scale at about  1/24 ~ 1/25 . Cardboard and tape test unit being made to day will post photos later . Thinking about power 1 or 2 motor , krots or not , fixed or steerable ,  ???
Timo2
« Last Edit: September 13, 2011, 00:11:52 by Timo2 »
Timo2
  • A buoy at heart
« Reply #5 on: September 13, 2011, 05:16:30 »
Hi All
   The Cardboard One !!!
« Last Edit: September 13, 2011, 05:22:30 by Timo2 »
« Reply #6 on: September 13, 2011, 05:25:41 »
Yup. That looks about right.
Timo2
  • A buoy at heart
« Reply #7 on: September 14, 2011, 09:27:13 »
Hi all
 In the tradition of "Arrow5" , just found a sheet of HDF melamine coated board about 7mm thick and very strong . Ha now to start cutting the hull and deck , still think about motor power ? how about twin 540 with gearboxes 2.5/1 on 6 volts and 40mm korts nozzles
   Timo2
« Reply #8 on: September 14, 2011, 11:11:43 »
modeltugman : The problem I have found that A lot of speed controls do not like 6VOLTS . They say 6 to 12  volts ,but when voltage drops monumentally for what ever reason they cutout .  On TUGS  I use 7.4  or  12 volts  and solves   that problem  . On the gear boxes I use 5/1 for bettor  bottom end control  , and still good top end .  Hope this is some help .                       PUFFIN
Timo2
  • A buoy at heart
« Reply #9 on: September 14, 2011, 11:52:10 »
Hi all
   Have cut Deck and hull parts, O they are hard and sharp edges , used a friends panel saw .
Deck Size 23" x 11 5/8" plus fender , hull 22 1/2" x 41/2" deep . Design of the Hull is flat panels with inverted Tray style deck to fit over . Glue up tomorrow i hope .
          Thank for you info , i have a very hard working Springer running on 6v SLA pack with independent BEC power , motor is a  540 2.5/1 unit will run for up to 3 hours at a time. but I will have a look 12v  . thank you
  Timo2
Re: New boys first scratch build
« Reply #10 on: September 15, 2011, 03:45:07 »
I had a 6V Mabuchi motor in my 43 inch tug which ran from a Futaba speed control. Worked great.
Check with Action RC Electronics for a suitable ESC.
Timo2
  • A buoy at heart
« Reply #11 on: September 17, 2011, 01:41:57 »
Hi All
        Power units will be 2 x 540 2.5 / 1 Motors with gearboxes run 40mm korts steerable nozzles, on 6 volt SLA batteries.
        Have looked at 12v with 6 / 1 gearbox but it has less revs , Ok more torque but not need with only a 40mm prop.
        ESC will be a ACTion P94 unit. setup as a mixer
  Timo2
   P.S. Hull Photos to follow
« Last Edit: September 17, 2011, 16:40:19 by Timo2 »
« Reply #12 on: September 18, 2011, 07:05:49 »
" ESC will be a ACTion P94 unit. setup as a mixer "
Can't go wrong there :) :)
Timo2
  • A buoy at heart
Re: New boys first scratch build ( Chame 11 )
« Reply #13 on: September 19, 2011, 10:44:02 »
Hi All
     Have cut and glue up the Hull , and cut a spare deck plate to work and test things out on .
     the glue is " Gator " a Waterproof Polyurethane D4 type, very strong . the hull size worked out at 297mm x  586mm ( 11 5/8" x 23" )  it will be a good size to carry.
  Timo2
« Last Edit: September 19, 2011, 10:50:48 by Timo2 »
« Reply #14 on: September 20, 2011, 03:29:02 »
Looks like a good start. Keep those pictures coming.
