Author Topic: New boys first scratch build  (Read 12790 times)
Timo2
  • A buoy at heart
Re: New boys first scratch build
« Reply #15 on: September 25, 2011, 03:02:20 »
Hi All
Not a lot of building this week , ( head not in gear just been make redundant ) but letís look  ahead , goods order  ACTion  P94 Mixer/ESC and  is  here , Steerable Korts  from  MMB here , Pair MFA 540=2.5/1 Motor unit and pair 40mm props order at local shop. Prop- shafts to be sized and ordered, batteries SLA type will order later from Components Shop, couplings to be machined in a friendís workshop.  :) Plus a new toy  ;D ( been in the cupboard for about 2 years a old  trade sample ) to play with a Xedoll  W50000 plus kit  8 x 3 machines , Fret saw, wood lathe, light metal lathe, Drill , Milling machine, Sander / Grinder, Dividing Head unit to fit drill or mill, and a hand held power pack.  Have try it out on copper water pipe and it work well I think we will have lots of copper based fittings.
Timo2
P.S.  Xendoll is chinaís version in aluminium of the Uni-mat
Just a Buoy at heart.
Timo2
  • A buoy at heart
« Reply #16 on: September 25, 2011, 04:15:50 »
Hi
    Xendoll unit
zeevaart1
  • www.bergingshaai.nl
« Reply #17 on: September 25, 2011, 04:26:57 »
Thats is a nice light machinery. :)
There you can create beautiful things with it.
I hope you enjoy your self with it.
with best regards Cor
www.bergingshaai.nl
Timo2
  • A buoy at heart
« Reply #18 on: December 02, 2011, 13:17:04 »
Hi All
 Still here and job hunting, more bit cut plus motors, korts, and couplings all there waiting on the local shop to get 1 more shaft, and a pair of props (over 6 weeks!!!) quicker from H.K. but they both do much scale stuff. More updates to follow
 Timo2
« Last Edit: December 02, 2011, 14:37:44 by Timo2 »
Timo2
  • A buoy at heart
« Reply #19 on: December 02, 2011, 13:19:35 »
More photos
« Reply #20 on: December 02, 2011, 16:48:06 »
Going to be a champ!!
Well done Timo.
Timo2
  • A buoy at heart
« Reply #21 on: February 18, 2012, 02:02:20 »
Hi Boys/Girls
  Back in  model making  business ,  "But still job hunting" ,  but need to get my head round to this build ,  OK,  after a very long wait the kort's props have arrived (  5 months  ) A very long story. Prop shafts designed and made ( 6mm OD brass tube , 4mm S/S Shaft , Solid PTFE rod , = Home made prop-shafts . ) P Brackets made, Kort's nozzles fitted plus servo , 2 kort's fitting discs cut , motor mount cut , should be starting to fit motors and shafts this week , Drawing of wheel house and deck fitting ,have started to work out sizing .
will post updated Photos soon
Timo2
« Last Edit: February 18, 2012, 10:58:55 by Timo2 »
Sudbury II
« Reply #22 on: February 18, 2012, 10:29:39 »
Looking forward to more.
"Suds"
Timo2
  • A buoy at heart
« Reply #23 on: February 18, 2012, 11:06:27 »
Hi All
   Found about 5-6 week ago on the great wide webb 1 new photo
  Timo2
Timo2
  • A buoy at heart
« Reply #24 on: February 28, 2012, 11:51:23 »
Hi All
   Back to the build , now have 2 super home made prop shafts 6mm OD 4mm S/S shafts and PTFE bearings , and updated flex joints with a bar to help line up , plus 2 P brackets .  Now to start work again  " AH " i have to drill holes in my new hull  :o
  OK more Photos
  Timo2
Timo2
  • A buoy at heart
« Reply #25 on: July 27, 2013, 01:25:19 »
Hi All
 Sorry it,s been some time , lost my workshop, new job working a way , O and build the GLW a new office , OK retried now , so back to proper work modelling, started to make new work bench in spare room ( please do not tell the GLW. )
   Update to last postings ,  1 = Shafts and Korts fitted and set-up
                                  2 = Control Servo fitted
                                  3 =  Power board and ESC/ Mixer ( P94 ) fitted
   Photos  =  https://plus.google.com/photos/105452072336401142655/albums/5901276996915227521?authkey=CNLGyvSlrZXhWQ[
Timo2
« Last Edit: July 27, 2013, 01:27:03 by Timo2 »
dmb
« Reply #26 on: August 09, 2013, 10:57:58 »
Hi Timo,
looking good!
am building the same tug but with 50mm steerable korts and a pair of Graupner 720BB Torque motors had the first water test of the bare essentials on Wednesday.
will name her Diablo II as it seems to be the sister tug to Chame II.
Here are some photos
https://picasaweb.google.com/116956959542958504127/DiabloIIPusherTug?authuser=0&feat=directlink
Cheers
dmb
« Last Edit: August 10, 2013, 11:17:30 by dmb »
