Author Topic: Meccano gears for towing winches  (Read 7738 times)
Tugboat Andy
« on: September 14, 2011, 18:17:55 »
 I was looking for some sort of worm gear winch set-up like Ray has on his tugs. I've discovered that Meccano has some brass gears that look suitable for building an towing winch. Anyone play with these sets as a younger person (the better question is: does anyone still play with their Meccano set...haha ;D) and are the gears worth looking into?
Thanks!
Re: Meccano gears for towing winches
« Reply #1 on: September 14, 2011, 19:13:29 »
Yes, they do work.
I've used them on a towing winch before.
Suds
« Reply #2 on: September 14, 2011, 21:51:23 »
TAMAYA gear boxes for cars work real well and they are very small ,and you can set them to your own gear ratio . I like the 240 / 1 set up.
PUFFIN
zeevaart1
  • www.bergingshaai.nl
« Reply #3 on: September 14, 2011, 23:09:50 »
I use also mecano.
But if I want more speed.
Or more power than I use belts.
with best regards Cor
www.bergingshaai.nl
« Reply #4 on: September 16, 2011, 12:25:30 »
I like your idea of using Meccano gears Tugboat Andy but the biggest problem is getting hold of the Meccano gears unless your name is James May? ;)
Tugboat Andy
« Reply #5 on: September 16, 2011, 20:01:18 »
Hee hee...  ;D Just catching up on Top Gear and James May Road Trip on BBC America (the free cable version...). I must say that I enjoy their silly and witty humor. ;)
Dizzyman2011
  • :) If it floats ... Push it :)
« Reply #6 on: July 27, 2013, 09:17:17 »
Meccano is relatively easy to get hold of on eBay guys
Just inspired me to make a winch now lol
« Reply #7 on: July 27, 2013, 11:01:50 »
HI ALL ; How do you stop them from running backwards when there is a load on it . The only way that I know is with a worm gear ,as it act's as a brake .                 PUFFIN
Dizzyman2011
« Reply #8 on: July 27, 2013, 13:39:04 »
Hey puff meccano do worm gears or should I say at least did worm gears
Yes that acts as a good brake or you could use a latch on the main drive gear same as 1:1 on trailer winch's doesn't have to be spring loaded if u use gravity and just connect it to a small lever to feed it out :)
« Reply #9 on: July 27, 2013, 14:29:45 »
hi dizzyman ; Thanks alot as I did not know MECCANO  had worm gears . Do you know a site that has MECCANO worm gears ?  Thanks again for the help . PUFFIN
« Reply #10 on: July 27, 2013, 15:55:57 »
Hi Glen,
Will be at Country Maples RV park in Chemainus for a week on Aug 12.  If we can arrange a meet, I can show you the gear unit I use for my Nederland tow winch.  There is no back sliding on it.
                                  Norm
Dizzyman2011
« Reply #11 on: July 27, 2013, 23:00:25 »
Morning Puff,
If you go on eBay type meccano worm drive
It's part #52 the later ones are plastic the early ones are all brass
Maybe try asking if they would post to US ? I'm sure one of them would if postage is covered hope this helps :)
« Reply #12 on: July 30, 2013, 21:26:59 »
HI OLSCUZBUT;  I will try and get something going for the 12 th or 13 of AUG.  .   We are going to  FOSS CUP on 15 th of aug .   PUFFIN
Dizzyman2011
« Reply #13 on: August 01, 2013, 02:09:51 »
Did u find a worm gear Puffin ?
A couple On there at the mo :)
« Reply #14 on: August 01, 2013, 08:43:49 »
hi dizzyman2011; No I did not find them .   I will look again .   PUFFIN
