Author Topic: springer tug  (Read 3488 times)
springer tug
« on: November 18, 2011, 03:59:38 »
he is  another springer build from me!  ;D it a grp hull  the running gear is : 3inch steering nozzel  70mm propshop 'prop'  m5 shaft  the motor is a graupner 700 with a 2:5:1 gearbox (ive tryed it in the test tank & its cool >:D :o) batterys will be 2 x 6volt 4amps  the deck is plywood the upper works are 1.5mm styrene  aprox scale is 1:32nd still got a way to go before  finished!!   regards ray
Re: springer tug
« Reply #1 on: November 18, 2011, 04:02:17 »
couple more
Re: springer tug
« Reply #2 on: November 18, 2011, 06:15:29 »
A tough looking springer Ray!
Might need larger drain openings on the deck!
Re: springer tug
« Reply #3 on: November 18, 2011, 08:17:54 »
Ray you did know the rules of the Springer.
1.5" prop 2-3 blade
Rudder no bigger than 4" square.
Thats open Wheel
6 volts max
We all know that your power starved.
Your springer is going to be more of a sub at speed.
Hope your water tight.
Re: springer tug
« Reply #4 on: November 18, 2011, 11:46:35 »
hi  mike & gary    i can run it in 6v or 12v  i may try 6volt first & then go from there?
gary im going for the unlimited springer 'class'  lol ;D  regards ray
Re: springer tug
« Reply #5 on: November 18, 2011, 12:26:39 »
now i no you have lost it  :o ;D ;D ;D ;D.
Nice one Ray
Re: springer tug
« Reply #6 on: November 18, 2011, 14:04:54 »
cheers tugnut ;D ;D ;D
