Author Topic: Kingston Lacy Build  (Read 31235 times)
Re: Kingston Lacy Build
« Reply #30 on: February 15, 2012, 03:37:32 »
Now for the chine infills. once again card templates ,transferred to ply,and cut out,there are some funny shapes though ??? ???
« Reply #31 on: February 15, 2012, 03:41:59 »
The infills were then glued and pinned in place and filler run through the join line and rubbed down.. the next jobs will be the anchor boxes, bilge keels and rudder,watch this space.  :D :D
caliph
« Reply #32 on: February 15, 2012, 06:41:52 »
Well I leave the country for a week and on return George has a tug almost on the blocks ! The quality of build is always a pleasure to see. No soon is Waverly away then Kingston Lacey is being born.
Looking forward to the next build pics and info. Great job George.  :) caliph
« Reply #33 on: February 15, 2012, 08:09:00 »
Thanks Brian,that will teach you ::) going on all these holidays. ;)
Now the bilge keels, the position for them was marked on the hull,and 4 slots marked out being carefull to miss the frames the slots were cut out with a jigsaw with a wide blade.
after a little trial and error the correct curve was marked onto some 2mm ply and the keels cut out leaving 4 locating lugs on each.these were pushed into the slots cut in the hull and superglued in place on the outside. body filler was used on the inside to seal the slots pushing it through to the outside where once dry the excess was sanded off.
the anchor hole positions were marked on the hull and cut out with the mini jigsaw,and simple boxes formed on the inside for the anchors, now it is time to seal the inside with some resin so the hull is now in the loft where the smell does not annoy S W M B O. angel angel angel
« Last Edit: February 15, 2012, 08:10:31 by model tugman »
« Reply #34 on: February 15, 2012, 08:13:12 »
Bilge keel and anchor box. :)
islander
  • Love the classics!!!!
« Reply #35 on: February 15, 2012, 10:19:43 »
Coming along very nice George.
Kinda like building the real boat huh?
« Reply #36 on: February 15, 2012, 12:20:31 »
yes same sort of process i suppose, I have helped build 25foot workboats along the same lines.
rea towing co
« Reply #37 on: February 15, 2012, 12:57:00 »
Hi George all looking good from here
It will be great to see the model of the lacy when she's done
You will have to come up with Brian and spend a weekend on the real thing !
I will get the fish and chips in for you !
Peter
« Reply #38 on: February 15, 2012, 13:03:22 »
Peter
that sounds like a good idea Peter, she seems to grow very quickly at the moment, she will slow down once the twinkie bits start and the painting starts as well.   all the best  Geo.
« Reply #39 on: February 16, 2012, 08:01:59 »
Well I have got a little more done today. I have filled and rubbed down one side,and primed it ,also fitted the chine strips these represent the weld lines on the chines, I have also made the skeg support behind the prop,
the deck I shall be making from 2 layers of 1.5mm ply and I have cut out and glued the first layer,the second layer will have the joins in different places,making a 3mm ply deck.
Because she will need a lot of removable ballast I will make the deck centre section liftout with the superstructure and after hatch, I don't think she will need a coaming to stop water ingress as she will have about 2" of freeboard midships.
« Last Edit: February 16, 2012, 08:06:54 by model tugman »
« Reply #40 on: February 16, 2012, 08:06:03 »
Skeg support and first deck layer waiting for the glue to dry. ;) ;)
« Reply #41 on: February 16, 2012, 08:56:05 »
 :o WOW :o George
Very nice you do work fast
Jason
« Reply #42 on: February 16, 2012, 09:52:04 »
:o WOW :o George
Jason
That is one of the benefits of being retired Jason,the wife is at work so my time is my own Lovely jubly.
« Reply #43 on: February 16, 2012, 12:58:47 »
:o WOW :o George
Jason
IM telling mags you said that, Looking good bruv ;D
« Reply #44 on: February 16, 2012, 21:23:07 »
Well said John, loose lips sink ships!
