Author Topic: PSV Lowland Prowler 1:70 Build  (Read 37320 times)
JEno
Re: PSV Lowland Prowler 1:70 Build
« Reply #75 on: July 17, 2019, 06:42:54 »
I am enjoying your build.
Double stack should not be an issue. I use it regularly. RFI can arise from it, but if good separation of power leads from servo leads occurs, it can be minimized. If you have not fittied capacitors to your motors, you should do so. What freq is your radio? If it is 2.4ghz, RFI should not be an issue, but induced currents from bundled wires can be. I hope this helps. Sometimes it is like trying to find a particular blade of grass...on a lawn.
Capt.Towline
« Reply #76 on: July 19, 2019, 23:29:24 »
Thank JEno,
Iíve still to isolate the interference issue so thanks for your support and advice.
Unfortunately some jobs around the house have taken priority and it might be a month or so before I can progress any further!
CT
