Author Topic: THE WEE DAVEY TOO  (Read 3963 times)
Re: THE WEE DAVEY TOO
« Reply #15 on: May 08, 2012, 10:59:03 »
Looks real nice Glen.
Are you leaving the stack as it is?
« Reply #16 on: May 08, 2012, 21:07:32 »
HI MIKE ,do you have any suggestions ? I'm always open to  suggestions . I'm sort of stuck on things to do next on the little fellow . I plan to put some tires on it . Bot it could use something more I just can't put my finger on it .     puffin
« Reply #17 on: May 08, 2012, 21:13:26 »
JUST A ADDED NOTE about the 12 volt lipo battery ,after one hour of run time i did not run it down enough to charge it .  That motor and gear box from SERVO CITY sure seams like the answer for small boats as it is only one inch X  one inch X one half inch in size .     PUFFIN
