Author Topic: another springer from me  (Read 8851 times)
« on: May 13, 2012, 08:24:24 »
hi all here is another springer  from me its a g.r.p hull   styrene upperworks  it has a 3inch nozzel & prop  a graupner 700 motor geared 3/1 i can run it on 6volt or 12  just need to add more detaill & the electric's inside  regards ray
Re: another springer from me
« Reply #1 on: May 13, 2012, 08:36:12 »
pictures i hope??
zeevaart1
  • www.bergingshaai.nl
« Reply #2 on: May 13, 2012, 08:50:59 »
Thats a nice cool springer tug
with best regards Cor
www.bergingshaai.nl
« Reply #3 on: May 13, 2012, 09:25:57 »
Thats a good looking springer Ray cool
« Reply #4 on: May 13, 2012, 18:43:30 »
Looks good Ray.
Deep hull eh?
« Reply #5 on: May 31, 2012, 23:10:07 »
well  i managed to get  sea trials in for this springer   yesterday   &  :-\ :-\   its mad!    i  am running it on 12volt (i can run 6v as well)   it dived at about half throttle to get water inside   but stood up on full throttle  :-\  regards ray
« Last Edit: May 31, 2012, 23:11:45 by ray28507 »
« Reply #6 on: June 01, 2012, 10:14:06 »
HI RAY ; Now that is some serious power . I tried APACHE on 14 volts four battery pack 2 in series 2 in parallel  and four pounds extra weight .  Not pretty .  Scrapped that idea .   PUFFIN
« Reply #7 on: June 01, 2012, 10:44:07 »
hi glen  i will be scraping the power set up on this springer  ill prob take the motor out & the nozzle to (its allmost 3inch)  regrds ray
« Reply #8 on: June 01, 2012, 11:14:37 »
Looks NORMAL for one of your tugs Ray :D :D :D :D
« Reply #9 on: June 01, 2012, 17:33:05 »
Ray
You have to remember the rules for the Springer. That's if your going to compete with it.
6 volts
1.5" prop 3 blade or less
18" long 8" beam
rudder no bigger than 4 square Inches ( the trick is the shape that you make it)
The rest is yours to do as you wish.
islander
  • Love the classics!!!!
« Reply #10 on: June 02, 2012, 08:02:48 »
Nice one Ray.
I see it performs well...like your others :) :) :) :)
« Reply #11 on: June 02, 2012, 21:12:44 »
 i am now going for a smaller nozzle & prop  50mm  :) regards ray
ChrisE
« Reply #12 on: June 02, 2012, 23:52:35 »
Any particular reason? Overpowered is good for towing but has it given you a problem?
« Reply #13 on: June 03, 2012, 00:27:22 »
 cool
Ray i would leave it mate keep like it is great fun :) :) :) :)
                     :oJust build another :o
Jason
« Last Edit: June 03, 2012, 00:29:19 by tugboyben »
« Reply #14 on: June 03, 2012, 23:34:17 »
hi   chris & jason  well i would have left it but the proplem i had was a half throttle it  just 'drove its self under '  bad!  & filled up with water    problem was the angle of the prop shaft  me thinks  but anyway its now haveing minor surgery  having a 50mm nozzel & prop fitted   ill keep you's updated  regards ray
