Author Topic: led light question  (Read 2082 times)
BIKERBOB
led light question
« on: July 24, 2012, 12:19:18 »
Possibly  one of the  members can enlighten me about LED lights
I am using 6 volt LEDs .50mA and have 4 wired in parallel (I believe). I was expecting that 6 volts would turn the lights on; but this is not the case; it takes 12 volts.  Should 6 volts turn the lights on? Can someone explain what is occurring or what I should expect if wired correctly?
Thanks
Robert Wager
AKA Bikerbob
FLJ
Re: led light question
« Reply #1 on: July 29, 2012, 00:07:24 »
It doesn't sound like they are wired in parallel. If all of the negative leads (the shorter ones) are connected together and to the negative of the battery, and all of the positive ones to the positive then 6v should light your 6v LEDs. Either that or you have 12v LEDs!
FLJ
« Reply #2 on: July 29, 2012, 04:48:21 »
Could it be that they need suppressors?
FLJ
« Reply #3 on: July 29, 2012, 08:37:08 »
I think you mean resistors, Barry, and you would only require those if the supply voltage was greater than the forward voltage. In this case it's the same (6v) - or so we're told.
FLJ
« Reply #4 on: July 29, 2012, 11:40:04 »
Dave,
I knew it was something like that!  ??? ??? You do remember how good my electrickery knowledge is!!! :-[ :-[ :-[
