Author Topic: ESVAGT CAROLINE  (Read 18456 times)
Re: ESVAGT CAROLINE
« Reply #30 on: October 31, 2012, 08:37:55 »
Hi all I seem to have lost a file of photos showing how I fitted the deck, :'( here is a photo showing how the build is at the moment.
« Last Edit: October 31, 2012, 08:39:34 by chipchase »
zeevaart1
  • www.bergingshaai.nl
Re: ESVAGT CAROLINE
« Reply #31 on: October 31, 2012, 12:41:42 »
i really like this model.
she becomes a real lady on the water.
with best regards Cor
www.bergingshaai.nl
Re: ESVAGT CAROLINE
« Reply #32 on: November 01, 2012, 13:49:17 »
Hi all the superstructure on the Caroline was not the easiest to build, here are a few photos showing the progress so far.
Re: ESVAGT CAROLINE
« Reply #33 on: November 01, 2012, 13:51:19 »
three more
Re: ESVAGT CAROLINE
« Reply #34 on: November 01, 2012, 13:54:32 »
more
Re: ESVAGT CAROLINE
« Reply #35 on: November 01, 2012, 13:57:43 »
another three
Re: ESVAGT CAROLINE
« Reply #36 on: November 01, 2012, 14:02:03 »
Last three
Re: ESVAGT CAROLINE
« Reply #37 on: November 01, 2012, 16:17:53 »
Nice work - don't you love working with multi angles!
I built a similar one for my Nanuq and am contemplating having another go at it. Ray built a similar wheelhouse - he liked the shape of these as well.
zeevaart1
Re: ESVAGT CAROLINE
« Reply #38 on: November 01, 2012, 23:28:29 »
 ^-^chipchase,nice details on the brige windows.
www.bergingshaai.nl
boatmadman
Re: ESVAGT CAROLINE
« Reply #39 on: November 04, 2012, 04:52:45 »
v nice work.
Any chance of some details on how you made the bowthruster?
Ian
Re: ESVAGT CAROLINE
« Reply #40 on: November 04, 2012, 07:40:02 »
looking good Brian, thats a lot of windowsto cut out
Re: ESVAGT CAROLINE
« Reply #41 on: November 09, 2012, 13:20:22 »
Hi Ian, just seen your post on the Caroline build, the bow thruster is made on the same lines as the Z drives but easier. If you look at the photo showing the bow thruster  you will see that I have used a 15mm copper T piece with a small section of copper pipe soldered in the end that holds the vertical drive shaft. I turned the end caps in the loath to hold the 10mm bearings; I used 2 bearings on each of the drive shafts. The shafts are m4 stainless steel and the bevel gears were purchased from Duval Gears. Hope this helps.
Cheers George,    you are right about the windows very time consuming,
boatmadman
Re: ESVAGT CAROLINE
« Reply #42 on: November 09, 2012, 13:37:56 »
Brian,
Thanks for that. Why did you choose bearings over bushes? And, how did you keep the water out?
Ian
Re: ESVAGT CAROLINE
« Reply #43 on: November 09, 2012, 13:59:25 »
I found that it was better using bearings to keep the bevel gears running true. I keep them packed with grease to keep the water out. I have not had any problems with this method up to now.
boatmadman
Re: ESVAGT CAROLINE
« Reply #44 on: November 10, 2012, 01:07:53 »
Ok, sounds good.
 Did you step the driven shafts at all in order to stop axial movement? Or did you rely on grub screws(?) or...?
Ian
