Author Topic: MIRIUM MORAN BUILD Thread  (Read 22775 times)
Re: MIRIUM MORAN BUILD Thread
« Reply #30 on: December 02, 2012, 07:11:10 »
Nice work - what thickness is the ply you are using for wheelhouse? Bracing behind it?
« Reply #31 on: December 02, 2012, 07:51:58 »
Looking good bruv,we might have some competion on here >:D :-*
« Reply #32 on: December 02, 2012, 10:32:15 »
Hi  Mike  the main casing is 1/8th ply and the wheelhouse is 1/16th with 1/8th square section behind the window frames and 1/8th bulkheads, the funnel is  two layers of 1/32nd ply steamed and curved around a ply former and body filler for the curved top.   Geo
« Reply #33 on: December 02, 2012, 10:33:58 »
Nice one little Bro I cant compete with you .
« Reply #34 on: December 03, 2012, 12:39:50 »
That is nice work, George. How did you make the M on the stack?
« Reply #35 on: December 03, 2012, 13:26:12 »
I don't want to be a party pooper but I bought a pair of those kort nozzle props from the Prop Shop and they just did not look right. There was just something not right with the boss/blade connection as something appeared out of proportion, maybe the boss was too small in diameter. Anyway I have two spare props now.
Maybe they have changed the design now. I don't know.
Nice build and a good scale with plenty of power. You are certainly getting on with it.
« Reply #36 on: December 04, 2012, 02:06:55 »
Hi   M T M   I cut them out of 1mm styrene sheet.  Geo
« Reply #37 on: December 04, 2012, 02:09:05 »
Hi Vanya,   I have had a good look at the props and all appears to be O K The boss if anything is slightly too large in Diameter but otherwise good.    Thanks Geo
« Reply #38 on: December 05, 2012, 07:04:18 »
 ^-^ I have now fitted the shafts and nozzles, and given it all some undercoat, the work now starts rubbing down and filling  not a nicejob :'( :'(
« Reply #39 on: December 05, 2012, 07:06:17 »
She looks different with some undercoat :-\
« Reply #40 on: December 05, 2012, 07:57:48 »
Looks Awesome!
At this rate...you'll be in the pond by the weekend :)
« Reply #41 on: December 05, 2012, 12:16:14 »
NICE  >:D NOZLES
« Last Edit: December 05, 2012, 12:19:06 by tugnut »
« Reply #42 on: December 07, 2012, 06:25:08 »
This week I have managed to get the Bulwarks fitted, what a job ???.
It really makes her look like a tug now. and also made the deck access hatches for the steering and the ballast compt.
« Reply #43 on: January 09, 2013, 08:56:12 »
Time for a little update on the build so far.
The wheelhouse is nearly fitted out just needs some varnish.and some paintwork cleaned up.
« Last Edit: January 09, 2013, 08:57:55 by model tugman »
« Reply #44 on: January 09, 2013, 09:01:15 »
The after deck side lockers and steering compt hatches are made and the working platform forward is made.
