Author Topic: WINCHES  (Read 6073 times)
WINCHES
« on: November 28, 2012, 10:08:05 »
HI ALL ; Looking for a WORM GEAR  for a winch I'm building . The gear needs to be about  one inch to one / half inches  ( 30 to 40 MM ) ,IN DIAMETER . The  worm  under  1/2 inch  ( 12 MM )  in diameter wide .    PUFFIN
zeevaart1
  • www.bergingshaai.nl
Re: WINCHES
« Reply #1 on: November 28, 2012, 11:27:06 »
This question I put to mister google, miniature brass worm gears
And he gave me this andwoord.
hope there's something interesting for you.
http://precision-gear.en.made-in-china.com/product-group/cbWnhvMKAGVl/Worm-gear-catalog-1.html
http://www.hpcgears.com/newpdf/hpc_cataloguesinside.pdf
« Last Edit: November 28, 2012, 12:11:35 by zeevaart1 »
with best regards Cor
www.bergingshaai.nl
Re: WINCHES
« Reply #2 on: November 28, 2012, 13:41:47 »
Hi ZEEVAART 1 ;That look like a interesting site but they only sell 100 to 200 at a time min.  pffin
cranton
Re: WINCHES
« Reply #4 on: November 28, 2012, 20:52:23 »
Check out Stock Drive Products which sell a HUGE variety of gears, pulleys, belts, shafts, etc, etc, etc, etc by
mail order and will sell small quantities.  They carry almost EVERYTHING you will ever need for your power system.
The prices are not unreasonable.  they will have worm gears.
Check out their website at:
http://www.sdp-si.com/
cheers
Chris
Love ships, turn green on wet grass
Re: WINCHES
« Reply #5 on: November 28, 2012, 23:08:31 »
HI CRANTON ; Thanks for the info .   PUFFIN
Re: WINCHES
« Reply #6 on: November 29, 2012, 04:58:57 »
Nice site, Chris. Thanks.
Re: WINCHES
« Reply #7 on: November 30, 2012, 16:51:35 »
Well will try this again.  Seems my post went off to never never land.  Maybe it was too long winded.
Puffin, hope you got the info you were looking for.  Built a winch under the deck from an old gear reduction unit from an old christmas ornament.  Ran the tow line thru the deck over the deck winch drum to make it look like it was working. It is a free wheeling drum.  Lots of tow line. Works fine on the bench.  Sea trials in the spring.  Controled by transmitter elivator control via servo and reversal switch.
Re: WINCHES
« Reply #8 on: November 30, 2012, 16:54:52 »
winch pictures
Re: WINCHES
« Reply #9 on: November 30, 2012, 17:05:08 »
Tried posting two more pics one at a time but get an message back that they don't pass security checks.  Guess I was lucky to get the one pic thru.
zeevaart1
Re: WINCHES
« Reply #10 on: December 01, 2012, 02:18:05 »
Or you can use a belt drive.
www.bergingshaai.nl
Re: WINCHES
« Reply #11 on: December 01, 2012, 07:50:07 »
very nice Zeevart.  Never thought of that.
