Author Topic: Mr.Darby  (Read 32014 times)
Re: Mr.Darby
« Reply #15 on: July 20, 2008, 08:32:32 »
Thanks for the info Keith!
If you know anyone who wants a Darby 're-build' project, 'puffin' (Glen N) up in Chemainus has one for sale, or knows who does.
$300.00 obo apparently.
CaptainSeaspan
Re: Mr.Darby
« Reply #16 on: December 30, 2008, 11:09:58 »
"It is a smaller version of the Darby by almost 10 feet according to the crew" The Dr Jack is the same as Mr Darby,MrPete,Godfather and a fifth one i can remember the name of all 149 ft 7400hp Alco v16the most notable diff is the DrJack had 8000hp .All simular looking boats to these were smaller with less power.ie Mr Charlie
Navy2000
Re: Mr.Darby
« Reply #17 on: December 30, 2008, 16:10:21 »
Here is what I did with my Darby hull that I had. THe brass color dot that is in the hull below the center of the structure is the coupling pin that would be remotely controlled to extend and retract into the slot that was on the barge.
Duane
« Last Edit: December 30, 2008, 16:11:57 by Navy2000 »
Re: Mr.Darby
« Reply #18 on: December 30, 2008, 17:32:09 »
..Too cool there Duane.. 8) 8)
That's the first ATB I've seen built off a 'Darby' hull.
How does she perform?
Looks like a pair of nozzles back there as well.
Did you go with the 'Harbor Models' variety or fashion your own.
Any more pictures??
...Cheers...
Re: Mr.Darby
« Reply #19 on: December 31, 2008, 01:23:34 »
Hello All   Here are a couple of pictures of a Mr Darby that I built and modified a few years ago
meechingman
  • Tugs rule, OK!
    • Andrew Gilbert's Website
Re: Mr.Darby
« Reply #20 on: December 31, 2008, 05:45:38 »
I really like that, a sort of Amsterdarby!
Andy
Admiral of the Haven Towage Fleet
Navy2000
Re: Mr.Darby
« Reply #21 on: December 31, 2008, 13:49:50 »
My ATB version of the Darby perform very well and yes there are Kort nozzles that have tripple rudder system hooked up as well. The barge that I made to work with the tug was 12 feet long anda 2 feet wide. I had to make the barge in two sections so that I could break it down for transportation. In all the barge when weighted down weighed in at just around 700 pounds and the tug had no problems in pushing it around the pond. When the tug was by it's self she would get a little rocky when wave action was on the large size when there were many boats on the pond and stirring up the water. I had compared it to another Darby that was built to the Dumas way and I was able to pull that Darby backwards with power to spare. I had used large Pittman motors on 12 volts that each motor ran at 3600 RPM's and direct drive to the props. Also when measured on a fish scale my pull on the scale would reach up to 28 ponds on fresh batteries.
Duane
Re: Mr.Darby
« Reply #22 on: December 31, 2008, 19:06:32 »
Hi Duane:
Lot's of pull huh?? Wow!! :o 8) 8)
More questions: :)
What props did you use...diameter and pitch?
Which Pittman motors?
Do you still have her??
I  just knew that someone...someday.... would make a 'Darby' into an ATB, as it's just the right hull for it.
Here's a picture of the last 'Darby' I built...as Crowley Maritime's 'Sea Venture'.
Twin 'Hectoperm' motors @ 3to1 reduction, 3.75" d props in custom aluminum nozzles.
This model is now in the Crowley Offices in Jacksonville FL.
...Cheers..and HAPPY NEW YEAR!!!...
« Last Edit: December 31, 2008, 19:13:23 by tugs53 »
Re: Mr.Darby
« Reply #23 on: December 31, 2008, 19:26:25 »
Very nice Model..Model Tug Man!!!! :) :) :)
Gotta know the details.....motors...props....electrics...etc!! :) :)
Happy New Years!!
« Last Edit: December 31, 2008, 19:33:38 by tugs53 »
Navy2000
Re: Mr.Darby
« Reply #24 on: January 01, 2009, 17:04:15 »
Hi Tugs53
The props that I had in her were from Prop shop at 3.5 inches in Dia and the max pitch that they had for that prop. The prop was also one that is used in kort nozzles only. I forget which Pittman motors I had in her but they were about 2.5 inches in dia and about 4.5 inches in lenght. I no longer have her any more sold her and about 8 months later the guy who bought had accidentally dropped the model onto concrete which damage the hull, he did repair it, but it became a differnet boat after that. He always tried to handel the boat with batteries still in the model when it was out of the water, I told him that was a bad thing to do, much easier with the batteries out of the boat when not in the water. Here are a few more shoots of her with the large barge that I had made for her to handle. With the barge connected she was 14 feet long and I would let some of the club members push me into the docks for fun. I have though of making another one maybe after I get a few of my Naval models done first, I am still trying to find some info on a UT 722L design anchor handeling tug would like to make one of them along with a UT 720 design as well.
Duane
Re: Mr.Darby
« Reply #25 on: January 01, 2009, 18:46:18 »
Really Cool there Duane: :) :)
I can see you've got your tug ballasted down to where she should be too!!
You know the design of bow you built into your barge, may well be coming to reality soon...according to some of the articles I've read in 'Trades' papers :) :)
Efficiency is a key concern these days.
Yup...you've gotta build another ATB Combo someday!
Don't really know where you'll find UT designs, other than from the owners or builders.
...Cheers...
« Last Edit: January 01, 2009, 18:50:51 by tugs53 »
Navy2000
Re: Mr.Darby
« Reply #26 on: January 02, 2009, 14:31:53 »
HI Tugs53
I have been trying so far I have by email a UT 755 design that I need to convert from CAD to a TIFF file so that I can have them printed up at the Blue Print shop. I have posted on this site about if it is possible t convert a UT 720 to a UT 722 design and there have been no replies to that post. Thanks for the comments about the ATB tug that I had, I do have a drawing of a 127 foot tig that I could possibly do the conversion to it has well for most of the ATB tugs seem to be around the 127 foot range, we will see that is a later project.
Duane
hama
Re: Mr.Darby
« Reply #27 on: January 02, 2009, 16:32:04 »
Hi there Duane, very impressive tug and barge! About the UT vessels, I guess you have seen the link I posted in the link thread a couple of days ago?    www.kagelmacher-modellbau.de
Hama
Re: Mr.Darby
« Reply #28 on: January 14, 2009, 12:57:03 »
Here's a good front deck detail shot of the Atlantic Salvor (ex: Mr.Darby)
« Last Edit: January 14, 2009, 13:02:01 by tugs53 »
Re: Mr.Darby
« Reply #29 on: March 05, 2009, 07:55:31 »
The tug 'Barents Sea', on the Columbia River.
Photo by 'Tuggerdave', flickr photoshare
