Author Topic: Plasticard....what thickness for where i.e for wheelhouse and decks etc???  (Read 2312 times)
davejay
Hi guys (& gals),
Just wandering what thickness plasticard I should use for the constuction of the wheelhouse on a freelance tug model in 1/32 scale and what thickness for the main deck.
I know a lot of you use ply etc but I'm going down the plastic route!!!
Look forward to your replies
All the best fellow tuggers!!
I normally use 2mm for decks and 1.5 for the superstructures,  I always strengthen between the deck frames  with ply were bollards are to be fitted before fitting the plasicard.
Hope this helps
davejay
Thanks Brian for your help, the thicknesses that you stated were what I was contemplating....at least my mind is working in marine modelling mode thank goodness!!!!
Regards, Dave
