Author Topic: Graupner Schottel Drive 1761  (Read 2629 times)
« on: August 01, 2013, 21:54:48 »
Does anyone know if someone makes a brass propellor that could replace the plastic one on a Graupner Schottel drive 1761? 4 bladed as per the image below. Held in with a circlip. The new prop needs to be able to drop straight in as I don't have any metalworking facilities/capabilities.
Re: Graupner Schottel Drive 1761
« Reply #1 on: August 01, 2013, 22:37:38 »
 take a look at prop shop  they do one for the shottle unit
Volker
« Reply #2 on: August 02, 2013, 00:36:30 »
Raboesch provides Kort propellers too: http://www.raboesch.com/CATALOGUS_2-2010_WEB.pdf
They are on catalogue page 5 or page 7 of the document. The propellers have a thread.
Same with the Prop Shop propellers: http://www.prop-shop.co.uk/index.php?id=32&section=store&sub_section=products
I don't know the Graupner Schottel good enough to judge if the standard threaded brass props will work. Perhaps you can contact especially the Prop Shop as they do custom castings: http://www.prop-shop.co.uk/index.php?section=services
Regards, Volker
seahawk 1
« Reply #3 on: October 26, 2014, 10:33:54 »
I know this is an old thread, however, if you still need brass props for this, I have several I had custom made.  email me at
michael42kf@gmail.com
« Last Edit: October 26, 2014, 10:38:21 by seahawk 1 »
I took an I.Q. test once..........The results came back negative.
