Author Topic: Bow thruster size.  (Read 2277 times)
boman
Bow thruster size.
« on: September 07, 2013, 17:23:43 »
Hello,
How do we work out what size Bow thruster is needed? Is there a formula? I have a barge, single screw, and highly un manoeuvrable. I wish to fit a bow thruster to her, to help the manoeuvrability.
How big? Draft is a scale 1.8m (50mm) Approx.
Any assistance will be greatly appreciated.
Re: Bow thruster size.
« Reply #1 on: September 07, 2013, 17:58:55 »
Hello Boman. . .bow thruster size formula? Good question. I also would like to know
a sort of "rule of thumb" method for choosing a bow thruster.
I must confess that I can't figure out the size of your barge. I would like to know
its length, width, how many inches of water it draws, and its weight. A picture would
be worth a thousand words here. Try to post one if you could.
I also am working on a design for a barge that is powered and utilizes bow thrusters.
You will receive many suggestions and I'll be reading them also, thank you for your
question and welcome aboard, Boman,
« Reply #2 on: September 07, 2013, 18:44:49 »
If your making it you can over size it a bit. If your buying one you are now limited to whats made.
Some of the units out there are about 1" dia. or 25 mm.
The motor of choice has a bit as in performance .
In scale probably about half the prop dia.
Some fellows just use a window or headlamp washer pump .
Water movement is what makes the unit more powerful .
Cost and availability are others.
boman
« Reply #3 on: September 07, 2013, 19:20:06 »
These pics are from my Sketch up file of the boat. How it will look after refit.
Length just over a meter. Width 165mm. Weight  I guess a kilo or so.( I have no real idea)
Single screw. Goes well. Built approx. 20 years ago. First boat I ever built.
« Reply #4 on: September 08, 2013, 18:05:42 »
The 1 " unit would probably work the best with a 400 driving it .
At a meter long and only a kilo in displacement . A windy day would rec havoc on such a vessel .
I have seen small warships not even get away from the dock , with small gusts of wind.
