Author Topic: flying spindrift  (Read 2920 times)
deepstar
  • 07885 318793
flying spindrift
« on: October 21, 2013, 14:55:28 »
hi
as any one built a flying spindrift
with  a single power motor and single kort nozzle???
if so how did it perform ???
what size  kort nozzle did you use
regards deepstar
lightshipman
Re: flying spindrift
« Reply #1 on: October 26, 2013, 13:46:27 »
I haven't built this model, but I did build a Mobile Mrine Models Nangee, and fitted her with single prop and steering kort nozzle, you will find the Spindrift very manoevreable with single prop and kort nozzle, but you will have to go up a bit on size, I don'y know what size the props and nozzles are on Spindrift, but I would probably go for 90mm on a vessle of this size, you will get a nice steering nozzle from Mobile Marine Models, and a nice prop from Prop Shop to mtch the nozzle. If you are going to stick with the kit nozzle and prop but only use one you will lose a bit some towing power, but speed will be just as good, and she should steer very well, even going astern. The only thing you won't be able to dois turn on th spot by going ahead on one and astern on the other motor, but by backing and filling you will till turn short round.
« Last Edit: October 26, 2013, 13:52:37 by lightshipman »
Nav Aids Tender Skipper
deepstar
  • 07885 318793
« Reply #2 on: October 28, 2013, 08:40:10 »
hi
is the photo of a spindrift or nangee???
i have just finish building my version of a nangee
 i put a  single kort nozzle on it
 i used a t12 motor
am well pleased
 would send you a photo
 but not sure how am no good on a computer
regards deepstar
