Author Topic: ASD 1/40th scale semi kit  (Read 1636 times)
mikearace
« on: November 11, 2013, 13:05:54 »
1/40th scale semi kit of a modern ASD harbour tug, with twin steerable kort nozzles.  Has been started with openings drilled for prop shafts and P Frames (not filed to a neat opening yet!!) and two windows drilled out in basic superstructure.  Kort shaft openings drilled and fitted  but tube supports not fixed in place yet.  There were a lot of heavy seam lines on the FG hull when it came and these have been sanded out although it will need some further light sanding to get a smoother finish where the heaviest mould lines were.  Main winch assembled.
Includes the Hull, two 555 motors, couplings, motor mounts, plan, FG Superstructure, cabin template, resin fittings and plastic card for the cab. Two brass P Frames also included which come extra to the kit as sold (a l, ittle oversized tube openings but can easily be lined with thin plastic tubing to get a perfect fit or any gap filled by other means) and also 1m of MMB rubber fendering 3mm diameter.  Retails at 175 plus postage but will sell for 125 plus postage at cost or pick up from Bristol area.
