Author Topic: red oxide  (Read 9131 times)
paultw
red oxide
« on: February 10, 2014, 11:18:31 »
Hi
Quite new to
this when using red oxide as  anti fowling does it need a coat of anything on top of it ???
« Last Edit: February 10, 2014, 13:24:04 by tugs53 »
Re: red oxide
« Reply #1 on: February 10, 2014, 13:25:46 »
I spray on a couple of 'light' coats of Krylon clear-satin coating,
paultw
Re: red oxide
« Reply #2 on: February 10, 2014, 13:49:53 »
OK ta i guess  we will have equivalent  over here
Re: red oxide
« Reply #3 on: February 10, 2014, 13:56:12 »
Just DON'T use lacquer paint!!
Re: red oxide
« Reply #4 on: February 10, 2014, 16:05:34 »
Hi Mike (Tugs53)
I've used an automotive clear coat (acrylic lacquer) on my AZIZ hull.  Why do you say DON'T use lacquer?  Should I be looking at refinishing with something else?
Re: red oxide
« Reply #5 on: February 10, 2014, 16:44:23 »
Hi Mike (Tugs53)
Lacquer in it's pure form usually reacts with enamel paint.  That annoying wrinkle effect.
If your application didn't do that initially; then you're fine.
paultw
Re: red oxide
« Reply #6 on: February 11, 2014, 01:17:29 »
I was going to use halfords red oxide and their satin lacquer so should be compatable
freightliner009
Re: red oxide
« Reply #7 on: February 14, 2014, 05:25:18 »
For what it's worth Wilko's red oxide is the dogs danglies, just painted my hull and used satin acrylic polyurethane varnish and there was no reaction, lovely finish.
« Last Edit: February 14, 2014, 08:25:25 by freightliner009 »
marky
Re: red oxide
« Reply #8 on: May 02, 2017, 03:41:36 »
Craig and Rose ,who make or made the paint for the Forth Rail bridge make a brilliant red oxide .
