Author Topic: MANAGEMENT OF PODS , Z-DRIVE or SCHOTTEL ON 360░  (Read 11934 times)
pinpinfou
Re: MANAGEMENT OF PODS , Z-DRIVE or SCHOTTEL ON 360░
« Reply #30 on: April 07, 2014, 23:31:05 »
Functioning in mode 2
Two ways only used on the radio. No cords Y. The computer interns made all the work
4 ways for pods two
Regulation of gases by pushing sleeve
Small video made there 3mn on the corner of the table
http://www.youtube.com/v/QUTMvV1AmnE
« Reply #31 on: April 09, 2014, 21:09:48 »
Very interesting. What is steering/turning the drives? Is it a motor/belt/geared?
pinpinfou
« Reply #32 on: April 10, 2014, 07:55:16 »
Excuse I but me does not understand the question.
Want to detail you please
« Reply #33 on: April 10, 2014, 12:52:58 »
Il souhaite savoir quel type d'entrainement est utilisÚ pour tourner le pod.
The belt (greyish) is visible in the video above the white support plate.
From what we saw in other posts I assume the belt is driver by a simple motor and there's a rotation sensor (rotatory encoder ?) with tells the control electronics where the pod actually points. From then it's a "simple" control loop.
A 2-axis stick is used on the control end, as seen here : https://www.youtube.com/watch?v=uhJLo0chXsg
Acrylic plate restricts movement to a circle (which is more or less what you have on the real thing)
Some quick trigonometry will let you turn the coordinates (X% left or right; Y% forward or reverse) to a bearing.
Controler uses motor and belt to turn the drive until sensor confirms drive is at desired angle.
« Reply #34 on: April 11, 2014, 16:50:49 »
Thanks
tbone
« Reply #35 on: May 04, 2014, 16:08:28 »
That last video of mode 2 looks good. So if I understand correctly from the center(neutral) position you can push the stick in any direction and it will go that direction with the amount of throttle based on how far from center it is?
Do you have any idea of price yet?
modslip
« Reply #36 on: May 07, 2014, 03:18:43 »
tbone
Pinpinfou is touring Scotland/Wales/Cornwall at the moment. Hopefully he will be able to give more info on his return.
Jackie
