Author Topic: Towing terms for the non initiated!  (Read 35766 times)
bigford
Re: Towing terms for the non initiated!
« Reply #15 on: August 02, 2008, 19:43:35 »
a blue and white flag hoisted by a ship when she is ready to set sail
more boats then money
« Reply #16 on: August 02, 2008, 23:51:45 »
GOOD ON YOU CAPT. JACK , BUT THERE IS ONE ROPE , AND IT IS ATTACHED TO THE BELL.
« Reply #17 on: August 03, 2008, 02:07:18 »
It is used to call the crew back to the ship prior to setting sail. It is a flag I believe.
Sorry Bigford, never spotted your post above..
« Last Edit: August 03, 2008, 02:09:02 by Footski »
Captain Jack
  • Uniform of the day at sea?
« Reply #18 on: August 03, 2008, 18:34:27 »
Now I would have guessed that to be a lanyard, but that term really doesn't fit. A lanyard is described as a "line being used to tie something off." So, "rope" it is...I stand humbly corrected! :)
« Last Edit: August 03, 2008, 18:37:55 by Captain Jack »
Fair winds, and following seas....
Captain Jack sends>>>>>
Captain Jack
« Reply #19 on: August 03, 2008, 18:45:27 »
A Bravo Zulu to both Bigford and Footski, but that is what it is used for in port. Can you tell me what the "Papa" (or blue peter), means when a vessel is at sea? ;)
Captain Jack
« Reply #20 on: August 03, 2008, 18:51:40 »
An easy one for this forum. A vessel flying the "Zulu" flag means what?
bigford
« Reply #21 on: August 03, 2008, 20:59:22 »
you need one of these ;D
bigford
« Reply #22 on: August 03, 2008, 21:04:40 »
capt jack
   Nets on obstruction
Captain Jack
« Reply #23 on: August 04, 2008, 04:42:42 »
capt jack
   Nets on obstruction
Arrrrrgh! Too easy! I guess I'll have to delve deeper into my old class notes to stump you my friend!
Ok, your turn to come up with a "stump the coxswain" question.
bigford
« Reply #24 on: August 04, 2008, 05:49:54 »
only thing i could come up with
 what or where is Fiddlers Green?
CGAux26
« Reply #25 on: August 04, 2008, 19:02:40 »
From the Colonies, the towing term "Hip Tow:"  This places the towing vessel alongside the tow.  It's useful in moving a tow around in close quarters, and docking the tow, where you can't get behind it.  The USCG method is to locate the towing vessel's stern aft of the stern of the tow, to give turning leverage.  Also, the towing vessel should be at an angle to the tow, with the stern swung out 15 degrees or so to overcome the sideways drag of the tow.  The preferred side figures the effect of prop walk, so a right hand prop tow boat should be on the port side of the tow.
Four lines are standard, and are preferably applied in this order:
1. Bow line, a brest line from the tow boat's bow as near perpendicular as possible.
2. Towing strap, a spring line from forward on the towing vessel to near the stern of the tow.
3. Stern line, a brest line at the sterns of the vessels.
4. Reversing spring, from aft on the towing vessel leading forward to the tow.
All lines are made up bar taut, except the stern line.  This is the secret to controlling the tow while turning and backing.  Lotsa fenders between the two vessels.
Dave
Dave
Captain Jack
« Reply #26 on: August 05, 2008, 14:22:36 »
an imaginary "heaven" thought up by those ne'er do well seafarers that figured they couldn't get into the Christian version of heaven. Most of Custers 7th Army cavalry soldiers also reside in this place, I'm told.
Captain Jack
« Reply #27 on: August 05, 2008, 14:33:12 »
Ah...the infamous hip tow. One more box to be checked off as part of our Coxswains certification, right?
Captain Jack
« Reply #28 on: August 05, 2008, 14:38:22 »
Ok, a tougher question, and I'll use the slang that you'd likely here on the bridge:
What is a mo-board?
bigford
« Reply #29 on: August 05, 2008, 20:28:48 »
Maneuvering Board
