Author Topic: Philippines scale bangka boat  (Read 10862 times)
seathug
  • patience is a virtue
Re: Philippines scale bangka boat
« Reply #15 on: September 16, 2014, 13:45:52 »
 Final assembly of my props
Next the motor, esc, servo, Reciever
and good to go
Im going to test this boat if its sea worthy  :)
Ill make sure I have a video for it
« Reply #16 on: September 17, 2014, 19:05:40 »
Very nice progress :)
seathug
« Reply #17 on: September 17, 2014, 19:35:07 »
Need to look for my lunch box
Guarantee this boat will be full of salt water when im done with it on the beach hahah
cant wait for the electronics to arrive
I want to see how this boat behave on the waves
seathug
« Reply #18 on: September 22, 2014, 20:48:52 »
This bangka finally arrived
And its bigger than I thought
Its 51 inchess long from tip to the tip
But its light weight
Now im worried about the mfa500 motor I have picked up for this boat
if it has enough power to turn my 3inchess 3blade props
seathug
« Reply #19 on: September 24, 2014, 10:52:41 »
Hi guys
this boat came with a props and driveshaft
but I dont like it
The sleeves for the driveshaft is to short
Im thinking itll be essy for water to get in from there
So im going to picked up a driveshaft with big props
What motor and props would you use if you want your scale model to pull you on a kayak?
Using 12v 6ah battery?
« Last Edit: September 24, 2014, 11:42:45 by seathug »
FLJ
« Reply #20 on: September 28, 2014, 02:48:18 »
You would have been better off sticking with the 800 motor which you were originally recommended. The 500 motor is completely unsuitable for a 3" prop unless it's coupled to a gearbox or belt drive of about 6:1. If you want more performance then the 850 motor will fit directly into the same engine mount and shaft coupling as the 800 but will take more current and therefore reduce the running time per charge.
I can't advise you on MTroniks speed controllers as I have never used one.
Dave M
tbone
« Reply #21 on: September 28, 2014, 08:48:29 »
A lot of guys here are using the Mtroniks speed controls without any complaints.
seathug
« Reply #22 on: October 01, 2014, 09:34:10 »
Hi guys
I have decided to ditch that props that came with the boat
Its much easier for me to just get a new props driveshaft motor esc battery
I think I can use the 6v12ah battery on this boat
it perform well on the beach hahaha
One problem
is when the waves come from the front
Itll just splash all over the boat lol
I think I will need a styrene cover for the hull
« Reply #23 on: October 01, 2014, 15:33:24 »
Looks REAL.
Well done
seathug
« Reply #24 on: October 01, 2014, 22:30:13 »
Thanx
Whe.n I tried pushing it on the water it glides so essily
Now im going to pick up driveshaft props and motor for this one
Oh and a waterproof servo
seathug
« Reply #25 on: October 08, 2014, 09:40:55 »
Ill be using an ac car blower motor for this boat
Strong enough to turn a big props
And efficient motor they said
seathug
« Reply #26 on: November 06, 2014, 10:59:28 »
Finally found the motor for this boat
Denzo motor :D
