Direct MFA COMO Drive 500 Size Motor
This high quality motor comes with motor mount and noise suppression compacitors.
Specifications:
-1/8" (3.2mm) Driveshaft
-6-12 Volt Operation
-13,350 RPM @ 12 Volts
-1-3/8" Can Diameter
-2" Can Length
And pair it with this esc
Tio Marine 15 Amp Electronic Speed Control
Forward and Reverse Marine ESC
NEW built-in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers recivers)**INDUSTRY FIRST***
Absolute short circuit and motor overload protection
-15A Current limit
-100% Waterproof
-6-12Volt (Input voltage)
-Power Connection made with Tamiya Connector
-Motor Connection made with Bullet Connectors
NOT FOR USE WITH A BRUSHLESS MOTOR
QUESTION is woukd this esc work for this motor?
And one of this
that should do it
