Author Topic: Sidewinder Build  (Read 5952 times)
Wishkah
Sidewinder Build
« on: September 21, 2014, 21:33:48 »
It's been awhile since I've had a chance to build again.  I've been remodeling my home for the past 2 years and I'm finally done so time to play. I've had this kit from Gary King since I finished my Alan B build. I was finally able to find an Schottel drive from Cornwall Model Boats. It took less than a week to arrive at home! I was impressed!
Wishkah
Installing the propulsion system
« Reply #1 on: September 21, 2014, 21:50:05 »
I removed the tiller setup that moves the schottel drive, and I will use a servo with a 60 tooth gear on it to turn the schottel directly. I'm using a 1000 KV brushless outrunner motor, 50A speed control on 6V SLA's
DSCN0648 by Whirlwind128, on Flickr
DSCN0641 by Whirlwind128, on Flickr
DSCN0654 by Whirlwind128, on Flickr
Wishkah
Fitting the deck and superstructure
« Reply #2 on: September 21, 2014, 21:57:40 »
A lesson I learned from my Alan B build.... It is a lot easier to fit the superstructure to the deck before attaching the deck. So a spent several hours sanding to get the fit just right.
DSCN0656 by Whirlwind128, on Flickr
Re: Sidewinder Build
« Reply #3 on: September 24, 2014, 06:09:56 »
Nice progress!
Those little "winders" are fun boats to RC; and Gary's kits are top notch.
« Reply #4 on: October 01, 2014, 15:37:17 »
Very Cool
« Reply #5 on: October 01, 2014, 23:22:01 »
there a good fun boat  i built one a while back   (one of garys kits)   your's is looking good!
Wishkah
« Reply #6 on: October 04, 2014, 20:28:30 »
Thanks All.
Hi Ray, I've been referencing your builds as I work on mine.
I've added battery boxes, Painted the inside, mounted the skeg, and setup some high strength magnets to hold the top in place.
DSCN0659 by Whirlwind128, on Flickr
DSCN0662 by Whirlwind128, on Flickr
DSCN0665 by Whirlwind128, on Flickr
Wishkah
« Reply #7 on: October 04, 2014, 20:30:55 »
some more photos
DSCN0667 by Whirlwind128, on Flickr
DSCN0668 by Whirlwind128, on Flickr
DSCN0669 by Whirlwind128, on Flickr
« Reply #8 on: October 05, 2014, 06:37:33 »
Looks good! That should be a fun little boat to steer.
What model schottel is that? It looks similar to a pair I have in a Tiger Sun model - I was looking for a replacement arm - shows up in your earlier post.
« Reply #9 on: October 05, 2014, 09:38:27 »
Krick in Germany has Schottel drives that look pretty close.
« Reply #10 on: October 05, 2014, 12:12:23 »
Photo 0641 shows the tiller arm -
Wishkah
« Reply #11 on: October 05, 2014, 17:11:08 »
Mike,
The drive is a CEM 40mm unit. I think it is the same size as the Graupner 1761. If you would like this tiller let me know, I won't be using it.
