Author Topic: DUMAS Carol Moran kit in the building process.  (Read 24045 times)
tug-arlyn-nelson
Re: DUMAS Carol Moran kit in the building process.
« Reply #30 on: January 30, 2015, 20:37:31 »
Bit of stern deck detail, fore deck detail and stern rubber.  I used some un needed oil filter canister gasket for that. Cut them in half and glued them on. Hokey but it does offer a bit of protection for the stern.
That's about it, been done for a bit. Would have loaded the pix during the build but that didn't work out. Its been in the water and runs great, I hope the vids I posted work for you. The first one wont but on page two at the top is 2 Photobucket vids that work.
Be happy to hear comments or answer any queries.
tug-arlyn-nelson
« Reply #31 on: February 13, 2015, 14:08:29 »
Here is a barge I made to put behind this boat. All plywood, painted with poly resin and paint.  Built to scale more or less, would be around 290', about right for a 105' tug.
tug-arlyn-nelson
« Reply #32 on: February 14, 2015, 13:02:20 »
Put the barge in the water today and towed it around, behind and alongside. Lots of fun!  I took lots of video too and if I can get any to upload to the bucket I will post them here.
tug-arlyn-nelson
« Reply #33 on: February 14, 2015, 13:09:06 »
couple more tried to load but are now failing the dreaded security check and they are all sized down same as the others.
tug-arlyn-nelson
« Reply #34 on: February 14, 2015, 16:23:04 »
http://vid1261.photobucket.com/albums/ii596/Scott3840/MVI_1178.mp4
Here is a vid hopefully of todays excursions into mini tugboating.
http://vid1261.photobucket.com/albums/ii596/Scott3840/MVI_1183.mp4
http://vid1261.photobucket.com/albums/ii596/Scott3840/MVI_1169.mp4
Hope you can see them! Someone let me know if they are working. They should open immediately and start playing.
« Last Edit: February 14, 2015, 16:25:49 by tug-arlyn-nelson »
Calimero
    • Calimero's RC shed
« Reply #35 on: February 14, 2015, 16:43:30 »
Vids work for me !
Nice tug and barge. Just add 40-50lb of ballast to the barge and you're done!
I'm currently building a barge too, mostly for my springer tug. 120cm*40cm (47"*16"). Was laying up some glass fiber just 2hrs ago.  I have four 10lb lead ingot to get it down.
I'll rig the barge with a very simple sheerlegs crane for an event next August where a bunch of 'Crazy Tuggers' will meet. Challenge is to maneuver the barge with two tugs and bring the load to the right spot. Should be a bit more interesting than just sailing around.
tug-arlyn-nelson
« Reply #36 on: February 14, 2015, 16:59:47 »
Glad to hear its working.  With this little boat and being all stock running gear, ie, small 1 inch plastic prop, I am afraid if I load that barge it will be like towing logs, very slow!  Right now it tows along about scale speed and looks pretty good. I wish I could load some of the better vids to the bucket but anything over about 40 secs or so wont load. Oh well.  Thanks!!
Calimero
« Reply #37 on: February 14, 2015, 18:26:56 »
That's when the fun starts: more inertia. Models behave closer to the real deal.
I've had a lot of fun towing a 300kg model with my 4kg springer. Took 3 or 4 seconds to  start turning even with the tow line at 90 which is much more realistic and challenging.
Regarding the videos: YouTube works great.
tbone
« Reply #38 on: February 14, 2015, 19:33:26 »
What are the dimensions of the barge?  Does it have frames inside or is it just a big box?
I agree that some more weight would help the barge and make it more challenging to maneuver. Maybe you can use water bottles so it will still be light to transport.
tug-arlyn-nelson
« Reply #39 on: February 14, 2015, 20:47:36 »
Barge is 48 inches by 12 inches wide.  No frames, just a box.  Half inch ply, resin and paint, a few nails and glue.  I should make up a bunch of containers for it, stack them 4 and 5 high like we used to do for the Bristol Bay and Nome trips!  Oh those were the days!
Next time out I will put a box of rocks on deck or something, call it a rock barge.
tug-arlyn-nelson
« Reply #40 on: February 14, 2015, 21:07:46 »
tug-arlyn-nelson
« Reply #41 on: March 13, 2015, 17:13:16 »
Put a new prop on this today, from Dumas. Same diameter, 1 inch, but 3 blade brass instead of 2 blade plastic. I was curious if it would make any difference in speed, thrust or towing. Well, all three.  Not a huge difference but noticeable.  Sure is a good looking little boat.  I will link to some fresh vids later.
Oh and check out the new rubber!
« Last Edit: March 13, 2015, 22:06:48 by tug-arlyn-nelson »
tug-arlyn-nelson
« Reply #42 on: March 13, 2015, 22:04:02 »
https://www.youtube.com/watch?v=1sznCkBErRw
https://www.youtube.com/watch?v=6mrc2e-gL4k
Pardon the occasionally shaky video as I am both running the boat and the camera!
« Last Edit: March 15, 2015, 15:30:34 by tug-arlyn-nelson »
Tiny69
« Reply #43 on: March 13, 2015, 23:49:03 »
Sails much better with the brass prop fitted.
Tiny
adam_goodin
« Reply #44 on: March 16, 2015, 15:47:52 »
Always liked these boats. Great model and the colour scheme is very nice.
Cheers
   -Adam-
