Author Topic: Westminster Apache  (Read 17038 times)
Westminster Apache
« on: May 22, 2008, 07:37:22 »
Here's a great shot of the Smit tug Westminster Apache, at work in the Fraser River, BC Canada, taken by member 'kingsway'.
Member 'puffin' has a great model of this tug, with enough power that he pulled the bollards right off the front of my barge!! ;D
Red_Hamish
Re: Westminster Apache
« Reply #1 on: May 26, 2008, 13:42:28 »
Hi Mike, I wonder what the comment was when you viewed the sequence of events on straining towline! Was it "Oh Boll 0&£ 5" ?
 :D A real nice looking tug anyway, I do like th Pacific NW ruggedness. just a shame the bollards weren't up to  the job  ;)
Jim
enjoy life and model boating not necessarily in that order :-)
www.edinburghmodelboatclub.org  or www.paddleducks.co.uk and the best place to live
www.visitshetland.com of course!
« Reply #2 on: May 26, 2008, 21:16:03 »
Hi Jim:
I've since drilled and bolted the bollards thru the deck of the barge.
Did'nt have time before the last regatta, so just glued them on.
** Good Tip: Always bring CA glue with you!!**
I'm hoping 'Puffin' will show us all some pictures of his 'Apache' model, which is under re-construction!  ;)
« Reply #3 on: July 09, 2008, 06:33:58 »
Here's a photo of 'Puffin's' Westminster Apache, taken last night, in his shipyard 8)
« Reply #4 on: July 09, 2008, 12:05:24 »
hi tugs53  very nice model  puffin  :)/ mike  is it  a brand new build?? looks like it will be ready for the foss cup??   regards ray
« Reply #5 on: July 09, 2008, 19:18:31 »
Hi Ray:
Glen bought her, in pieces, and rebuilt the whole boat! :)
He did a fantastic job, as usual 8) 8)
« Last Edit: July 10, 2008, 06:40:56 by tugs53 »
« Reply #6 on: July 09, 2008, 21:22:23 »
Like that winch! Bits and pieces or...?
Big jump from when I last saw it - something about being retired bantered about!
Good job.
« Reply #7 on: October 18, 2008, 14:39:13 »
How's this tug coming along Glen??
Last I heard, she could pull the sides right off the pool!!
How about some pictures Glen!!! :) :)
Such a cool model, you know 8)
« Last Edit: October 18, 2008, 15:11:31 by tugs53 »
« Reply #8 on: October 18, 2008, 14:51:54 »
HI MIKE ; What are those rudders called that have a bar at 90  degrees on the trailing edge of the rudder .    PUFFIN
« Reply #9 on: October 22, 2008, 17:25:40 »
I think you're refering to 'Flanking Rudders'.
Anyone else have any idea's??
Here's a picture of one of the sisterships to your 'Apache', showing lots of deck detail. Thought you may find this usefull!
« Last Edit: October 22, 2008, 17:32:46 by tugs53 »
« Reply #10 on: October 23, 2008, 16:46:40 »
Hi Mike
Nice photo there - gives lots of ideas for deck stuff!
Always like those - need to get a winch sorted out, mine look pretty sparton compared to other tug models!
« Reply #11 on: October 23, 2008, 22:29:56 »
hi mike /  tugs / puffin    is this what would be  a 'muscle brov' ? hull in model terms
regards ray
« Reply #12 on: January 19, 2009, 19:44:57 »
Glen:
How are you making out with your 'Apache' refit?? ;)
« Reply #13 on: January 19, 2009, 21:17:14 »
HI mike ; Should be reddy for a relanching by the end of the week .  PUFFIN
CaptainSeaspan
« Reply #14 on: January 20, 2009, 11:07:24 »
""HI MIKE ; What are those rudders called that have a bar at 90  degrees on the trailing edge of the rudder"" .......................Im not sure about the bar your refering to Glen but the Apache doesnt have flanking rudders....Flanking rudders are FWD of the nozzle and are mostly used on the towboats of the US interwaterway ,the big pusher boats you would see on the Missisippi.The Apache doesnt have Becker type rudders either but it does have a Jastram type system which allows independant use of each side instead of a normal use.Apache has 4 rudders 2 on each nozzle.the rudders on the Apache are mounted on the bottom as well with a pintle pin hope this helps......................Paul
