Author Topic: Next one on the slipway HMRT. Growler  (Read 15153 times)
« on: May 12, 2016, 08:44:45 »
This is the next one to be tackled, unfortunately the hull is not the right shape forward as it has no flare to the bow,and it was very prominent on these boats.
So I am going to have to build the bow out with filler and fibre glass, to allow this to be done the hull needs stiffening as it is very flexible, plenty of deck beams and inwhales are required and a thin under deck so that tha shape can be got right.
Re: Next one on the slipway HMRT. Growler
« Reply #1 on: May 12, 2016, 09:17:47 »
A couple of pictures showing the flare forward on the real thing and the hull shape as mould end.
« Reply #2 on: May 12, 2016, 10:05:20 »
Hi George
Great start ill tag along look forward to next update  :)
Jason
« Reply #3 on: May 12, 2016, 11:43:18 »
You were out of the blocks quick.
Look forward to another one.
« Reply #4 on: May 13, 2016, 12:40:47 »
I have started to fill the bow in order to get the flare,and fitted the fore and aft bearers the bow had to have to pieces fitted to get the right deck shape and to give me a line to fill out to, that's all for now,   Geo
« Reply #5 on: May 13, 2016, 12:41:39 »
The deck beams fitted
« Reply #6 on: May 16, 2016, 07:15:12 »
Another problem found with this particular hull moulding is that the stern is the totally wrong shape and the Skeg ends too far foward,if measured to scale it puts the prop 26 feet foward of the stern,so by using ply and filler I have re shaped and extended the skegfurther aft,this gives an added bonus of now being able to swing an 85 MM prop instead of the 70 MM gap that was there before.
The pictures show the original keel and the modified one in progress of being made.
« Reply #7 on: May 16, 2016, 07:16:46 »
This is the modified keel
« Reply #8 on: May 18, 2016, 10:55:14 »
A bit more done to Growler,I am using up all my odds and ends of timber whilst waiting for the stuff that I have ordered.
The motor mount is made ,as are the bilge keels,the engine room skylight,and funnel.
And a start has been made on the superstructure.
« Reply #9 on: May 18, 2016, 10:55:50 »
A couple more
« Reply #10 on: May 18, 2016, 11:31:23 »
George, you're a machine!
« Reply #11 on: May 18, 2016, 11:57:58 »
Yes an old slightly knackered one👴🏻👴🏻👴🏻👴🏻😄😄😄😄😄😄😄👍👍👍
« Reply #12 on: May 19, 2016, 12:59:28 »
The foward deck is now fitted and I have done a bit more to the upper works.
« Reply #13 on: May 20, 2016, 07:01:58 »
Looking good! Fast progress!
« Reply #14 on: May 20, 2016, 11:29:29 »
George You do work fast look's great  :)
Jason
