Author Topic: Next one on the slipway HMRT. Growler  (Read 15286 times)
Re: Next one on the slipway HMRT. Growler
« Reply #15 on: May 20, 2016, 12:35:59 »
Hi guys, it is all only in its rough state yet just carcasing it all then the filling and sanding starts.
« Reply #16 on: May 21, 2016, 03:24:37 »
The bow bulwarks are on,and a couple more bits are done now ,it looks different with a coat of undercoat as well
« Reply #17 on: May 28, 2016, 10:19:12 »
Another little update to Growler, some nice topcoat and window frames in the bridge as well as some handrails, oh and I have made the tow hook, been promised my wood order and fittings next Tuesday.
« Reply #18 on: June 01, 2016, 07:53:31 »
Well the wood and fittings arrived as promised good old MMM.
So after deck is now glued in , the rudder made and servo fitted , motor and coupling in and lined up.
And started making and altering some fittings.
« Reply #19 on: June 01, 2016, 13:10:07 »
That tow hook looks good. Is that standard fitting?
« Reply #20 on: June 01, 2016, 14:28:43 »
I made it up from the drawings that I am working from they came with the hull.
They were all fitted with the 30 ton bollard pull Spring hook with a built in roller over the top as the towing winch was fitted just ahead of the hook and the roller allowed the cable to clear once it was swung to the side.
In the picture of the Foundation Josephine ex Salvonia on the rocks you can make out the layout.
« Last Edit: June 02, 2016, 10:48:18 by model tugman »
« Reply #21 on: June 02, 2016, 07:36:17 »
Another day and the after deck is looking better
NickelBelter
« Reply #22 on: June 10, 2016, 08:13:32 »
Very nice 'clean' work, George.  :)
« Reply #23 on: June 10, 2016, 09:58:02 »
Thank you kind sir, a little more done over the last couple of days, fitting made up and painted and some undercoat on the decks,
« Reply #24 on: June 10, 2016, 15:01:53 »
Anxious to see this one on the water. Nice.
« Reply #25 on: June 12, 2016, 08:13:55 »
Great job on the details and painting!
« Reply #26 on: June 14, 2016, 07:37:04 »
Finally got some paint on her hull at last and the decks are painted with topcoat, more handrails to make and paint and the lifeboats have to be rigged,than I shall attack the making and rigging of her masts,
After that it is a matter of fixing the fittings in place and wiring up the motor etc.
« Reply #27 on: June 14, 2016, 09:46:02 »
Great job  George
You do work fast
Jason
« Reply #28 on: June 14, 2016, 22:17:24 »
Oh he is not so fast.  Just kind of like greased lightning!  Looking good George!
« Reply #29 on: June 14, 2016, 22:41:05 »
Thank you gentlemen.  It is not so fast as having plenty of time to play really,and having been making model tugs for nearly 60 years,you get to know the little wrinkles that help make things easy.  Geo
