Author Topic: Springer Tug in Vienna!!  (Read 4294 times)
Gerhardvienna
« on: October 06, 2016, 09:36:00 »
Hi @ all...
While I`m still working on my Bison tugboat, I decided to have another build for the cold season. So I gathered some infos about springers, and started yesterday with the build. The plans come from Mak Sui-shin, as they were posted at RC-Groups, http://www.rcgroups.com/forums/showthread.php?t=522762. Somewhere I found some good drawings for the superstucture, and my admiral lokked at them and decided which one to build. The hull is basically completed now, just a bit of grinding and laminating missing. I used 3 mm balsa wood for the hull, I had more then enough for the full hull! So I will not need to buy too much for this winter project.
Gerhard
Gerhardvienna
Re: Springer Tug in Vienna!!
« Reply #1 on: October 14, 2016, 10:42:35 »
Found some time to work on the Springer again, the superstructure is almost done, have a look..
Gerhard
Gerhardvienna
« Reply #2 on: October 20, 2016, 06:46:17 »
Update, once again.....
The stairs to the wheelhouse are done and fit well in place, used some old wood stripes for that.
Gerhard
Comments WELCOME!!
Gerhardvienna
« Reply #3 on: October 26, 2016, 07:15:14 »
Hi again...
The Springer`s wheelhouse has got windows. They are made from 0,5mm clear plastic sheet, and fixed with wood stripes of 0,5 x 1mm plus 1 x 4mm measure.
And the roof has its final colour, just the position lights still mising.
Best regards
Gerhard
« Reply #4 on: October 26, 2016, 10:52:16 »
Looks good!
Gerhardvienna
« Reply #5 on: October 26, 2016, 11:33:48 »
Looks good!
Thank you!!
Stay tuned in, there is much more to come from that Springer...
Gerhard
Gerhardvienna
« Reply #6 on: October 27, 2016, 21:17:45 »
Next things done at the wheelhouse, interior is set in. The floor was downloaded from the net, by searching for "Schiffboden Bilder" , also all the other paper parts as the compass and the monitor. The map on that little monitor shows the Vienna harbour Freudenau.
Gerhard
