Hi guys/gals
Been at this on/off for around 8 months so far but the past few weeks I decided to go full on with it & I've got quite alot done, hoping to have her ready for sale for the summer
This is my first ever build.. yup I jumped in at the deep end as they say \o/
Anyway will let the pics do the talking, as I say, its a largescale TID Tug details are:
Hull: T.I.D Harbour Tug, Glass Fibre (Models By Design)
Scale: 1/12 (Length: 71" & Beam: 18")
Motor: 24volt DC 12 Pole - 3800rpm
Power Source: For Motor: 4x 12v 22AH SLA battery's (Total output: 24v 44AH - Series/Parallel configuration)
For Aux: 1x 12v 22AH SLA Battery
ESC: Action Electronics P98 High Power (Modified)
Prop: Brass 5" (12.9mm) 4-Blade
Prop Shaft: Mobile Marine Models MaxLine 12.5mm Brass Outer tube / 8mm solid stainless steel inner with bearings
Rudder: Brass
Misc. items
Sound Unit: Beier Sound Module USM-RC-2
Smoke Unit: Steam Master Unit (SMU)
Electrics:
Action Electronics P98 High Power ESC (Modified
Action Electronics P107 Switched Power Distribution Board (Modified)
Action Electronics P103 Parallel Power Board (Modified)
Action Electronics P95 Indicator Fuse Boards
Action Electronics P112 Fused Power Distribution Board With Main Power Switch
Action Electronics P44 Universal Twin Switcher
More info about my build can be seen here:
http://www.tizdaz.co.uk/boat/build.htmlHULL
