Author Topic: Machine bending machine  (Read 5398 times)
romanov
    • RC Tug
« on: June 11, 2018, 10:42:28 »
Hello
I made a tool for bending sheet metal :)
Bending tool designed to work with photo etched parts. It is high quality tool, excellent for every modeller. It is used by hobbyist building tanks, trains, etc.
Adjustable steel bendig blade allows maximal benging lenght of 175mm. In case of metal sheets with thickness between 0,4 and 0,5mm maximal bendig lenght is 50mm
Maximal Bendig width 175mm
Minimal Bendig width 2mm
Maximal Bendig angle 135 degrees
Gap adjustment between table and beding edge 0 to 2 mm
Overall tool Sice width 200 mm, height 16mm, depth 100mm
Tool weight 1400g
Romanov
« Last Edit: July 14, 2018, 12:50:44 by romanov »
Re: Machine bending machine
« Reply #1 on: June 11, 2018, 17:57:23 »
Looks nice.  Would like to see how it works.
romanov
    • RC Tug
« Reply #2 on: June 13, 2018, 00:47:18 »
Hello :)
I will make a video in the near future.
Romanov
« Reply #3 on: June 14, 2018, 11:03:42 »
Romanov.
That is very nice work on the machining.
Do you have some dimensions and capabilities of the bender?
Would be nice to bend thin brass and steel for miniature locomotives with something like this, also to make radiused bends.
Hayden
romanov
    • RC Tug
« Reply #4 on: June 18, 2018, 04:44:34 »
Hello
The bending machine is 175 mm working width. 125 degrees angle.
I post a movie as it works. On the film I'm bending 0.2mm sheet metal
Sorry for my English
https://youtu.be/Brj_JVTRqbQ
Romanov
« Last Edit: June 18, 2018, 04:47:05 by romanov »
