Author Topic: Svitzer FERRIBY  (Read 17990 times)
0 Members and 9 Guests are viewing this topic.
Re: Svitzer FERRIBY
« Reply #45 on: August 18, 2019, 02:20:28 »
Morning Chum
Nice tug you have built have you had it on the water
Jason
chum444
Re: Svitzer FERRIBY
« Reply #46 on: August 18, 2019, 02:47:49 »
Thank you folks. It has been in the water at the early stages of construction for ballast testing. That splash was an indicator that learning to control those Schottel drives will take awhile. Hope for more sail time soon.
 Lot more work to do.
chum444
Re: Svitzer FERRIBY
« Reply #47 on: October 08, 2019, 09:37:14 »
After finishing BUGSIER 18, back to work on FERRIBY.
chum444
Re: Svitzer FERRIBY
« Reply #48 on: October 08, 2019, 11:11:08 »
Any of you folks have photos of FERRIBY’s tow winch? Particularly looking for details of the gearbox,port, side.
Thanks in advance.
chum444
Re: Svitzer FERRIBY
« Reply #49 on: November 27, 2019, 09:18:14 »
I’ve been working on the tow winch. Some photos of the start of construction.
« Last Edit: November 27, 2019, 09:19:54 by chum444 »
chum444
Re: Svitzer FERRIBY
« Reply #50 on: November 27, 2019, 09:21:50 »
Winch completed prior to installation.
Re: Svitzer FERRIBY
« Reply #51 on: November 27, 2019, 10:26:56 »
Good work Bill.
Re: Svitzer FERRIBY
« Reply #52 on: November 27, 2019, 13:21:36 »
Looks good - did you build it yourself from scratch, or is it a kit?
I'm guessing that this is the forward towing winch, as it has the anchor chain gypsy as well.
Des
chum444
Re: Svitzer FERRIBY
« Reply #53 on: November 27, 2019, 13:58:55 »
The hull is a modified TIGER KING hull. Not exactly the FERRIBY’s hull form but the closest I could find. Since there was a less than zero chance of obtaining the lines from Damen, a scratch built true to type hull was impossible. FERRIBY only has a forward winch.Everything else scratch built.
A few more photos of the winch in place after installing the bulwarks.
Thanks folks for the nice comments.
« Last Edit: November 27, 2019, 14:01:24 by chum444 »
Re: Svitzer FERRIBY
« Reply #54 on: December 01, 2019, 16:02:01 »
Hi Chum
Yeah your right zero chance of getting any hull lines from Damen for your Ferriby model and any Damen design come to that. Also any tug design by Robert Allen the Canadian boat / ship designer is the same you might be lucky with a general arrangement drawing but hull lines they won't release. Good interesting project your doing there Chum.
chum444
Re: Svitzer FERRIBY
« Reply #55 on: December 01, 2019, 16:55:05 »
Kev,
 The photos you so kindly provided were a tremendous help. If you have ever done a model using proportional measurements from a GA drawing and or photos you know that eventually scaling errors will show up. Certainly the case here but I feel fortunate they seem to be rather minimal but obvious if you know where to look.
 Thanks again for your assistance.
Re: Svitzer FERRIBY
« Reply #56 on: December 03, 2019, 14:04:35 »
No problem Chum that's what these forums are here for exchanging info etc. I actually enjoy taking photo's of the tugs I'm building as it makes it easier to build your model as you also take a tape measure to take relevant dimensions so you can scale these down. I was working in Newcastle UK for 4 months some years ago and managed to get a morning off work to go and take pictures etc of the Svitzer tug Fiery Cross based at Middlesbrough as I had arranged through their office to go on board the tug. I arrived at the Svitzer base at 09.00 and never got out the car for the first hour and a half as it was absolutely hammering down with rain. I've got back since but Boro was 30 miles south of Newcastle not 272 that it is from Bristol???
If I'm down near Southampton again Chum I'll look out for both Damen tugs working for Svitzer the Harty and the Ferriby and post some more pics on to you. If you go on the SMS towage website they have a new Damen tug based on the river Humber the Manxman I'm not 100% sure how it compares to the Svitzer tugs in layout etc.
chum444
Re: Svitzer FERRIBY
« Reply #57 on: December 14, 2019, 05:11:08 »
Kevin,
 The SMS Manxman &Marksman are both Damen 2411 ASD tugs. Very similar in arrangement to FERRIBY. Looks like their tow winches are bit different probably because both SMS tugs are newer than FERRIBY.
Thanks for the reference.
Bill
chum444
Re: Svitzer FERRIBY
« Reply #58 on: December 14, 2019, 19:11:25 »
Getting closer to completion.
Re: Svitzer FERRIBY
« Reply #59 on: December 14, 2019, 20:37:24 »
Looks good - but why did you lay the boat on its side / end to take the first & last shots?
I particularly like the window glazing - looks like flush glazing, with raised edges AND rounded corners.  I have only been able to achieve any two out of three on my windows so far - I'm hoping I can do better on my current project.
