Author Topic: my 'springer' geting there!!!  (Read 15239 times)
« on: July 16, 2008, 13:13:30 »
 hi all this be my springer so far!  the sides /bow& stern are 6  x  1 inch floor board  & 2mm ply bottom doubled up where the prop / rudder is  at this tim it has a 50mm prop on (will change to 40mm when finished (maybe!!)  the deck is 2mm styrene as all the rest (when finished)   regards ray
Re: my 'springer' geting there!!!
« Reply #1 on: July 16, 2008, 20:37:29 »
Mighty Fine Ray :) :)
Whatcha got in mind for your housework?
« Reply #2 on: July 16, 2008, 22:22:46 »
Ray,
Looks good. Keep posting as I have just started mine and am a novice to this class...Building her as Tessa PG which is a tanker, my sone is Chief Mate on...Not an easy task!!
HS93
« Reply #3 on: July 17, 2008, 00:46:04 »
Ray I like the way you have done the running gear . I have been looking at a way of doing it without the normal wooden keel and that looks similar to a tid witch I had not thought of, off to cut brass.
Peter
« Reply #4 on: July 17, 2008, 07:53:00 »
hi  tugs  the wheelhouse i had in mind maybe seaspan tempest?? im doing it in 1;24th scale
hi footski  ive not been able to get my teeth right into it  >:( as ive other projects on the go!(boats of course :D) but as & when i will keep you all posted :) :)
hi hs93 yes all i did was make a skeg etc out of brass & the rudder is brass   regards ray
« Reply #5 on: July 18, 2008, 06:34:50 »
Hi Ray:
Seaspan Tempest eh?
Good choice. Wait till ya see Doug's 'Seaspan Venture(s)'.
He's built two so far, one just for playing in the pond.
« Last Edit: July 18, 2008, 06:38:51 by tugs53 »
« Reply #6 on: July 30, 2008, 12:46:50 »
hi all a little bit more done (slowly but surely) ;)  regards ray
« Reply #7 on: July 30, 2008, 19:25:01 »
Coming along really good Ray!
Got your bags packed??
Bring some asprin, you'll need it!
« Reply #8 on: July 31, 2008, 09:03:18 »
hi tugs no ive not got anything packed yet  but the most important thing i have got ready is my model tug :D :)  so whats the asprin for???? regards ray
« Reply #9 on: September 28, 2008, 09:40:45 »
hi all im back on the building the springer now built a wheel house friday  :)  regards ray
« Reply #10 on: September 28, 2008, 10:28:00 »
Looking good ray  :)
I will have to start building.
All the best john
« Reply #11 on: October 06, 2008, 12:41:42 »
hi all  got a little bit more done  the upper steering postion & almost ready for painting   regards ray
« Reply #12 on: October 06, 2008, 14:25:24 »
HI RAY ; Looks great . I have been at a stand still of late . Have you seen gary's new dozer boat. Are you going to  S1  the inside of the springer .     PUFFIN
« Reply #13 on: October 06, 2008, 22:32:55 »
hi puffin  i have seen gary new dozer boat  after the springer & another small project   i might see about getting one of them :) regards ray
« Reply #14 on: October 18, 2008, 04:23:05 »
hi all  not much done only a bit of 'color' added  ;) & a robbe navy motor geared 5:1  on 6v or 12v installed & battery trays
regards ray
