Author Topic: my 'springer' geting there!!!  (Read 15177 times)
Re: my 'springer' geting there!!!
« Reply #30 on: November 07, 2008, 22:59:43 »
HI RAY ; Like the use of the hair curlers on the exhaust .   PUFFIN
« Reply #31 on: November 07, 2008, 23:13:22 »
hi tugs thanks  there maybe no 2   (or a canadian tug of some sort would be good :-\ :-\)
hi puffin  i have hair roller all shapes & sizes & painted i think they look ok :D (my other half's a hairdresser so endless supplys  there  ;) )  regards ray
« Reply #32 on: November 08, 2008, 13:42:45 »
IM glad you said that iWAS begining to wonder :-*  ;D ;D
manxman
« Reply #33 on: November 15, 2008, 23:05:27 »
Hi Ray,
She looks really great, never ceases to amaze me at the ingenuity of modellers to see and adapt everyday items, I would never have 'seen' the potential of a simple hair roller.
Great work - cheers, Ken
« Reply #34 on: November 16, 2008, 00:29:16 »
HI RAY ; Some of the haircurlers [older ones ] that had a brush inside make good ones too . Thats the ones that where on the dorothy . They are getting hard to find now,but thank god for the dollar stores.
   PUFFIN
« Reply #35 on: November 16, 2008, 06:06:02 »
hi manxman   this one is plastic  idid have some that were metal  (which was great because they went rusty! natural weathering  ;)  but i cant get the metal ones any more  just plastic  ::)
hi puffin   the metal ones were the better one of the 2   :)  but like all things they must come to a end ::)    (any way how are you ?  are you building more boats lately?   (ive got a nanuq from ron b  to build but i need 2 graupner voith units first (so ill hold fire  on that for a while)     regards ray
« Reply #36 on: February 22, 2009, 09:30:59 »
 well after many weeks  ive finaly sea trialed the springer!!    it went very well no problems to report!  (only one thing i might change is the gears  from 5:1  to  3:1  just to give it a bit more go!) lol  regards ray
« Last Edit: February 22, 2009, 09:36:12 by ray28507 »
« Reply #37 on: February 22, 2009, 09:40:13 »
few more
« Reply #38 on: February 22, 2009, 09:45:42 »
some more
« Reply #39 on: February 22, 2009, 09:56:38 »
Looks great Ray!!
More "Go"??
How much more do you need?
tango
« Reply #40 on: February 22, 2009, 10:01:40 »
You beat me to it Mike, I think it has enough go, looking at the bow wave washing the decks. But then again there is no such thing as a motor that is too powerful.
Looking good though Ray.
Will it be up for Springer football at Wickstead? Looks too nice to get involved with us hooligans!!!!!!
MARK.
« Reply #41 on: February 22, 2009, 11:57:42 »
HI RAY ; That sure look's good . If you change to 3: 1 let me know your results . It will possibly less run time ,and the engine will run hotter. What batteries are you using ?           PUFFIN
« Reply #42 on: February 22, 2009, 12:38:05 »
Well ray i can see from pict the theropy didnot work ;D ;D.
No realy thats another great tug to your fleet :).
well done.
« Reply #43 on: February 22, 2009, 12:39:51 »
 hi tugs  it had the 'steaming power' but just not much towing/pushing power!!  im useing robbe navy motors this one is 12volt = 5;1  (im running it on 12volt & its under proped for the current motor the prop is the biggest one i can get in there 50mm x 55 pitch 4 blades ) ive used the 5;1  with 97mm props)  so  what im going to do is change  for a robbe navy 3;1 on 6 volts this should match the prop better)
hi tango  im hopeing to get to the wickstead show!  just depends if i get my car fixed!by then (clutch is sliping!!)  im up for a game of footy!
hi puffin   thanks   im running 12volt  but when i change to 3;1 ill be on 6volt  i have 2 x 6volt 4amp jell cell batterys in her
                                      regards ray
« Reply #44 on: February 23, 2009, 02:14:17 »
HI RAY ; I have one in the planing . I plan to use two 7.2 volt packs ,and the five to one reduction . The 4200 mah batteries are lighter and last longer . This will give me 8.5 amps of running power and less weight . I have been changing over most of my boats to these pac's and I'm really satisfied with them .
            PUFFIN
