Any ideas on the best glue to use with plywood and softwood?
I'm thinking particularly in relationship with a springer, I intend using 6mm marine ply for the hull sides, front and rear panels, 2mm ply for the hull bottom,
I want to use 6mm softwood for deck support and corner gussets, I intend fastening the deck support and gussets with small brass screws after applying the appropriate glue, but I find there is so many different brands and types and different opinions it gets alittle confusing
Any suggestions gratefully accepted.
Peter.
